Old 10-06-2007, 01:17 PM
mackbm mackbm is offline
Default Transom Trim
I am replacing my set of twins and going to a single. The aluminum trim around the transom needs to be replaced. Is there any ideas on what I could use for that and where I can get it?
Old 10-06-2007, 06:12 PM
Default Re: Transom Trim
I tried to replace mine a few ago without success. It seems the angle/bend at the corners required a special jig. I took it to a custom fabricator and got sticker shock
I would build one out of PVC board or get "Strick" to make ya one out of fiberglass and then paint it
Old 10-06-2007, 08:58 PM
I'm tired of making stuff I still have to make a leaning post for this darn boat I'm working on. I wonder if marine connection would have some of that stuff laying around. You may have to cut/heat/bend it or something to make it fit right.
Old 10-07-2007, 01:00 PM
hermco hermco is offline
You could grind and glass the seam,paint with gelcoat. Better than covering up with trim.
Old 10-07-2007, 02:45 PM
lost2a6 lost2a6 is offline
That is what I did to my Sceptre.
Steve B
1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH!
1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop
Old 10-07-2007, 01:43 PM
JohnB JohnB is offline
I have both pieces of stock trim for a 23' single motor boat in pretty good shape that I posted a coupld of weeks ago for sale. If your interested, the price was right, free, or maybe toss a couple of bucks toward the CSC site.
If you need pictures or want more info, let me know.
JohnB / 23' SeaCraft
Old 10-08-2007, 04:38 PM
Howard Hill Howard Hill is offline
Go here - mcmaster.com Do asearch for "Aluminum Trim" and you should be in business.
Old 10-10-2007, 06:26 PM
Here are the pictures of the transom trim.
It measures 53" wide at the top, with a 19" wide in the middle with 14" at the bottom where the motor is.
The trim is 1 3/4" wide, and it comes with 2 pieces, let me know if your interested or I will pitch in the alum recycle pile.
Old 10-10-2007, 07:10 PM
Thanks for the offer John but those won't work for me
Old 10-10-2007, 10:01 PM
I'll hang on to it for a couple of weeks, once I get finished with my boat, and clean up, I will toss it then.
