Old 10-18-2007, 09:13 AM
Default 18 owners feedback
I just purchased a 1978 18 foot cc and had a few questions I was hoping some current or former owners could help me answer.
1,) Livewell – What is the best plan of attack here? I know from reading the archives that the original setup pretty much makes this livewell useless except for hauling around 40 gallons of rainwater. I would really like the ability to have this as usable space so I would prefer not sealing it up permanently.
I was thinking of cutting out the livewell and improving the gutter system so that it would not fill with rainwater. Also, I would like to be able to make the livewell a lift out / removable well so that I could have access to the bilge. Any ideas as to weather or not this would work?
2.) Deck drainage system--
Is the 18 footer self bailing or not? Currently there are two drain holes in front of the motor well that drain directly into the bilge. I would rather plug these and have the water run out the two drainholes located in the transom. If I put the ping pong ball style drain covers on the transom will this be sufficient to let the water out of the boat?
I am trying to come up with a plan of attack to address these issues and any help would be appreciated.
Old 10-19-2007, 01:42 PM
Tashmoo2 Tashmoo2 is offline
Default Re: 18 owners feedback
I have an 18 ft '86 Seacraft and just started replacing the deck after procrastinating for 3 years.
1. My boat has a 135 HP Mariner on it. My drain holes (which drain out the transom) are always plugged. I've read that deck should be raised at least 2" if you want a true self bailing cockpit. I will probably not as it will leave very little freeboard inside. My '72 23 ft boat had a great scupper system that syphoned water out the bottom.
2. The bait well ahead of the engine is useless and I just cut it out.
3. You might find a few pictures of a gutter system if you do a search through the rebuild stories. I decided against it as I do not see benefit. I will attempt to camber the new deck outward. right now I am leaning toward Nidacore as I want this deck to last.
4. This is a great riding little boat and other then dealing with outboard engines and fuel problems I am very happy with it.
Old 10-20-2007, 12:50 PM
vcs vcs is offline
The 18 is a great hull, I have a 76 that had a 20 in transom, it had a Evinrude 150 on it and was always taking on water from the scuppers and over the transom from the weight of the 150. I put the pingpong style on it and it helped reduce the water by at least 75%. If you cut out the back of the live well you will have access to the bilge area. I put on a flotation bracket and closed in the transom, The scuppers were relocated so the hull is still self bailing.
Old 10-20-2007, 07:02 PM
Ikan Besar Ikan Besar is offline
I had a '76 18' and I don't personally think a Potter era 18' with a modern day outboard is a self-bailing boat.
That compartment in the floor directly in front of the engine wound up being a trash recepticle in mine but I've seen others that were plumbed to be a livewell.
Old 10-22-2007, 06:44 AM
waltert waltert is offline
Hi All,
I just bought a 1989 Tracker built 18 cc, do these later model years have an improved self bailng cockpit?
Walter
Old 10-26-2007, 07:57 PM
Waltert-
The Tracker Hulls do have better self-bailing vs. the 80's hulls and probably the Potter's too . The weight is less, and I believe the placement of the console is more forward as well, so your chances at self bailing is good. Anything over a 358 lbs 130 Yamaha is asking for the ball scuppers or keeping the plugs in while cruising. I have a great deal of experience on this boat and 3 different motor set-ups and they do run hard and are a pocket type center console that can take the slop that others of similar size cannot. As for that floor live well, cutting it out for bildge access is a good idea.
Old 10-23-2007, 08:56 PM
76Red18 76Red18 is offline
I have a 76 18' with a lighter weight 99 Johnson 150 and 25" transom. I use ball scuppers which work well to keep water out but only drain when the boat is moving. I installed bait wells under my leaning post and use the "live well" for my bait well pumps and transducer. I plumbed the well with a 500 gph auto pump and just pump out the water that does get in. I made a splash well board from starboard with drains witch I usually keep pluged. We use lots of live bait here in S.W. Florida, so I also plumbed the front well to hold a couple inches of water for when the bites really on!! These 18's are great boats which draw very little water and still handle rough water well. Enjoy!
J. M. Hendrix
Old 10-31-2007, 12:03 AM
SnoFoolin SnoFoolin is offline
deepsushi- my 78 18' has the drains out the transom- pingballs fixed most of the problem. also moved console and fuel tank 4" forward. 115 e-tec pushes boat just fine + weight - much less than 150 etc. Baitwell floods- haven't solved the problem but use a drop in bilge pump to pump it out- after a very heavy rain. Thinking of closing it off and using the thru hull for removable baitwell nearer console- under leaning post. Great boat- had her since she was born.
Old 11-02-2007, 12:34 AM
MARLINT220 MARLINT220 is offline
I've got an 1987 18'. I had the same problem with the useless floor well filling with water that came in from the low transom "ramp". I made a board out of 3/4" starboard and put a piece of "u"-shaped mohogany on the top for a cap. I ran a bead of silicone to keep the water out. Works great! Looks nice too! I also use the ball-scuppers by rabud. To drain the floor well, I drilled a small hole and installed a strainer/plug set up that goes into the bilge. The only thing I have used the well for is lobster in the Keys. For live bait I use a 23 gallon kodiak removable.
