Old 12-05-2007, 03:43 PM
HunterAllen HunterAllen is offline
Default Just Picked Up 1969 20'....Need Restoration Advice
My father and I just picked up a 1969 20SF. It has a usable 140 Suzuki on it. The interior and exterior paint have to be redone, I want to replace the leaning post, and put a t top on. I need any and all advice on the proper way to go about doing these repairs as this is my first restoration on a classic hull. The main things I am trying to get at now are the best order in which to complete each step. I figured to take everything off of the boat that I can, to facilitate in getting the best paint job possible. This is not going to be a total redo like I see many of the boats on here are, but get the inside and outside looking good and make it fishable. Please help as we need all the advice we can get and bare with me as I am sure I will have more questions. Here it is:
Old 12-05-2007, 04:22 PM
76Red18 76Red18 is offline
Default Re: Just Picked Up 1969 20'....Need Restoration Advice
Heck, it looks fishable now. If you dont want to do a complete resto do a sniff test in the fuel tank compartment, if no smell its probably ok but a pressure leakdown test would be better; hook the trailer to your vehicle, tilt the motor up and jump on the lower unit. If you dont see any flex in the transom where the motor is bolted then it should be good for a couple years; next, walk the entire deck, if you feel any soft spots jump on them a little, if ya dont fall through, the decks alright for a while; check your wireing for corrosion and loose connections spray some B-9 on the terminals and check that everything works; check steering and control cables ; check your bearings and tires on your trailer; If everything seems ok , go fishin
IMO , I wouldn't waste the time or money to paint the inside unless I was going to do a total resto; I would fill and protect any screwholes to prevent any water intrusion..I'd try somekind of finish restorer on the outside before I repainted. Take the time to do searches on this site and you will find everything you need to know, Richard
J. M. Hendrix
Old 12-05-2007, 05:09 PM
You need to make sure the deck is solid enough to hold a tee top. if it is the orginal deck it may not be! just something to think about!
Old 12-05-2007, 05:13 PM
Trayder Trayder is offline
Velvet Jones
That is a nice boat, it was for sale here as well. My father had the little brother to your Suzuki 140, the 115, on his 19 mako and it is a GREAT motor. Had some odd corrosion but was great on fuel and oil.
welcome aboard.
Old 12-05-2007, 06:20 PM
Oh, the transom is only a couple of years old and the deck feels fine. My concerns are that the tank is in the console and I would really like a smaller footprint on the console so that a cooler could be upfront instead of a seat only. I realize it is fishable now, but want to do a half redo; as in paint, leaning post, t top, cushions, livewell, trim tabs. I just need to figure where to start. I guess ripping everything off to prepare for any fiberglass work and painting would be first.
Thanks for replies.
Old 12-06-2007, 10:24 AM
WillyC WillyC is offline
Changing up the console is something that many of us here have done. I cut four inches out of the middle and removed the seat in the front to make room for an ice chest. I think it is right at 28 inches wide now - just about the same width as a 94 quart ice chest.
I'm not certain about your boat but you may have to deal with a raised lip that the console is attached too. If your tank is in the console, I would think about putting the gas tank in the floor like the newer boats. This would be alot of work as you would have to cut a hole in the floor, fabricate a hatch cover and lip in the floor for the hatch to rest on. In my opinion, very worth it to get the tank in the deck where it belongs and free up space in the console. -will
