Old 12-07-2007, 04:13 PM
stevebrownell stevebrownell is offline
Default Respiratory protection while spraying
There are a few posts showing members (and some professional boat restorers) spraying their hulls with standard face masks with various cartridges (for organic vapors, presumably) Given that spraying Interlux Perfection without a positive-pressure system is a very bad idea, what topside paints are being sprayed here, or are people just throwing caution to the wind here and going for it?
I'm strongly leaning towards roll and tip when the time comes, but spraying some parts of my boat would make sense, but the option of spraying Perfection is not on the table, neither is gel coat.
Feedback? Options?
19XX? 20' I/O
Old 12-07-2007, 05:00 PM
bigeasy1 bigeasy1 is offline
Default Re: Respiratory protection while spraying
Several years ago,i sprayed one of my boats with sunfire,a two part urethane that is like Imron,and contains isocyanates which i found out later,require an air supplied respirator.
At the time,the guy in the automotive paint store where i bought it,told me that a regular organic respirator would be fine.
I worry about this now,and from time to time,wonder if it did any damage.
I'm going to spray my Tsunami with a two part urethane this summer,and will definately use the correct air supplied respirator.
I think it's to risky to cut corners when it comes to something that could possibly kill you.
All this,just for a boat ride
Old 12-07-2007, 08:01 PM
GroveGuy GroveGuy is offline
Being a painting novice, I used Perfection to Roll and Tip my hull and am pleased with the results. To spray or not to spray I guess depends on your experiece, budget, access to equipment and, as you are apparently well aware, adherence to safety precautions. Count my vote to Roll and Tip!
Good Luck
1969 Seacraft SF20 / 2003 Yam 130
"And the sea shall grant each man new hope. . ." -
Old 12-07-2007, 11:26 PM
Ditto, except I rolled/tipped Awlgrip. In my job as a yacht captain, I get see the "Form over Function" trap all of the time, and Seacrafts are all about FUNCTION!! If you want it pretty, do it with all the proper precautions.
Lloyd
Old 12-09-2007, 10:07 PM
3rdday 3rdday is offline
The interlux perfection is awsome. it is very durable and is self leveling co it can be rolled and brused or sprayed, it is a 2 part style. It is flexible an has incredible sheen. Just make sure no bugs are about! Learned that one the hard way
Old 12-09-2007, 10:34 PM
glow glow is offline
My father is a professional auto body refinisher and works for the local Peterbuilt dealer here in Hawaii. Spraying AwlGrip, Imron etc. is very deadly and should only be sprayed while using supplied air systems. He also worked as a paint rep for Sherwin Williams and learned about how they make paints as well as the hazards of using them without Personal Protective Equipment. Check out the MSDS (Material Safety Data Sheets) and they should give you a list of the hazards, how to use (PPE) and Signs/symptoms of exposure. Isocyanate poisoning can be fatal and has long lasting health consequences. Take care of yourselves for the sake of your loved ones as well as yourself. Being a do it your-selfer is meant to be fun and gain a sense of accomplishment. Let's all be around to enjoy our SeaCrafts and share them with the future generation . GOD Bless and Aloha from Hawaii, Greg
Old 12-10-2007, 01:58 AM
BigLew BigLew is offline
Greg is right!!! Spraying Awlgrip is NOT for the unprepared!
We had a customer at West Marine who sprayed Awlgrip and thought the protection was for the "Pros" who had repeated exposure. He sprayed in the afternoon and died at his dinner table that night from the poisoning he had given to himself.
These finishes are great products, but if you don't want to spend the money on the safety equipment and the time learnign HOW to do it safely, do your family a favor and get a PRO to do it.
Plan accordingly!
