Old 12-11-2007, 11:09 AM
Keyscruz Keyscruz is offline
Default Bottom paint removal
Does anyone have any wisdom to share re EASY bottom paint removal? There are many old coats and the surface is very rough and uneven. Would prefer soda blast but can't seem to find reasonable price in So. Fla.
Old 12-11-2007, 06:43 PM
Default Re: Bottom paint removal
There is a chemical agent out there that claims it removes bottom paint, Don't know if it works or not? Ive seen it at boaters world
Old 12-11-2007, 10:04 PM
Do a seach on THT for "bix"......there was a thread where a guy described the whole process and what he used.
Old 12-11-2007, 10:10 PM
CJR CJR is offline
There is a product called " Peel Away". I tried it when
I redid my bottom. The results were so-so. I wound up having a guy sand it off and gelcoat the bottom. You used to be able to buy Peel Away @ Home Depot, a lot cheaper than West Marine.
Old 12-16-2007, 02:49 PM
EagleOCNJ EagleOCNJ is offline
Peel Away works good for me. Still a lame job no matter how you do it. LIke he said DONT buy it from boats stores, get it from Home depot. 1/3 the $$$$.
Old 12-16-2007, 04:31 PM
I found this web site.
Soy Paint Stripper
Old 12-11-2007, 10:50 PM
Tom Fabula, who owns Signature Finish, recommends use of a chemical stripper. Says to give it plenty of time to work, and should be able to scrape off w/putty knife. Said to plan on going over it a couple of times, as first coat won't get everything. Also said to plan on some light sanding to get whatever is left.
Old 12-11-2007, 11:46 PM
BigLew BigLew is offline
There is a product by "Captain John" that is carried by some West Marine stores. It is a store manager's decision on whether to carry it or not. There was some talk of putting it in the inventory on a company wide basis.
Anyway, we had a demo of it one weekend at West when I worked there. First, it is all natural with no caustic components. Two, you need to leave it on and not let it get below 50 degrees. Once applied, (roller, slabbed on by brush or sprayed) it needs to be covered with suran wrap or some other non-poruos film product. Even leave it on all night. Afterward simply take a plastic blade and scrape it off down to the gelcoat letting it simply fall into a paint tray or bucket. (The removed bottom paint is toxic!)
We took 5 coats of bottom paint off a wooden dingy with one application leaving only what paint there was embedded in the grain of the wood. About 80-90% of the wood was totally paint free. The stuff works!
Captain John's web site is:
http://www.captainjohnsboatbrite.com/Soy.htm
He's got a whole line of cleaner/polishing products and I use them for my car, boat, etc. Great products and a real nice guy to deal with!!!
Plan accordingly!
Old 12-12-2007, 12:24 AM
I guess this means the stuff you scrape off has to be taken to local household hazardous waste disposal site?!
Old 12-12-2007, 08:03 AM
It should be properly disposed of. Its the the dopper in the paint that is toxic, not the pint remover. The paint remover is soy based, but it really works!
He has another product called "Icky-Sticky." My daughter crunched the side of my car door pulling the car into the garage. (She's just getting her lisence). Miner metal bendindig, but a fair amount of paint on the car door. The icky-sticky took it all off in about 4 minuts with NO hard rubbing like you'd expect with rubbing compound. That stuff is citrus based and smells like oranges! Go figure!!
for what it's worth, the thing I'm most impressed is that "Captain John" has his cell phone number on the back of every bottle and takes your call!! He'll answer any question you've got to ask!!! The guy knows it works and believe me, it is better than anything I have used to date.
Plan accordingly!
