I am looking at a 1970 20' CC w/ F115 Yamaha. Can anyone let me know what I may expect for performance? MPG, speed and so on. The owner didn't have specific info. Thanks for the help. Any other info may be halpful. I don't have any experience with these boats...just heard Seacrafts are A+.
Danny [img]/forum/images/graemlins/tongue.gif[/img] |
Maybe just a pinch underpowered but not too bad, those usually were rigged with inline 6 150 Merc's. Being thats a V block will help with the low end and I would say about 40 for top end. If you were repowering I would say a 130 to 150 but a deal is a deal, just water test it should be OK.
Your performance with the 115 should be just fine. Many of the 1970 to 1983 20' SeaCrafts were rigged new with 85hp and 90hp V4 Evinrude/Johnson motors, and did just fine. Figure a WOT speed of 38-42, and a cruise of 25-28 depending on prop, rigging, LCOG, trim tabs, etcetera.
And you'll laugh at all the old carb'd 150's and 200's as they fill up at the gas pump ![]()
Seacrafts are A+
1984 Seacraft 20' SF. W/2004 Mercury Saltwater 150 http://i98.photobucket.com/albums/l2...LOGODONE-1.jpg |
I'm running a 1972 20'er with a 115 Johnson 4 stroke (Suzuki). I'll get 33kt at 5600. it's too fast in anything but the flattest water. the boat is most comfortable around 24kt (4000rpm). Did I say how quiet she runs?
I have a 76 20' Master Angler with a 140 4S Suzuki and wide open with one person on board and a full 60 gallons of fuel I only get 31kts. I don't remember what the top rpm was. I do have a large T top, tabs and a stock aluminum prop. Before this boat I had a 20'SF with an Evinrude 120 looper and it was faster but I don't remember by how much. It had a doghouse.
every boat will be slightly different in fuel burn and speed but as more people post you will get an average. I have a '71 20CC with 140 Suzy 4-stroke and get 40mph with a full 75 gallon tank and at 30mph get 5 mpg. Use those numbers with the others you get to get a ballpark figure.
