Old 02-05-2008, 03:23 PM
BendLure BendLure is offline
Default Aft well filling when running
I have a 1998 seacraft 23’ with twin merc 150 EFIs. The live well in the deck behind the leaning post is always filling up with water. The live well fills up when it rains, and also when I am running the boat. Does anyone else have this problem? I understand the rain filling the well. Maybe I can seal the lid better. When running it almost seems like water is coming back through the drain pump and into the well. Is that possible?
Thanks for any suggestions you guys might have.
Schedule Sea
23' Seacraft
Twin 150 Etecs
Old 02-05-2008, 04:32 PM
SteveH SteveH is offline
Default Re: Aft well filling when running
I currently have a 2000 23 footer and have the same problem with water ending up in my "below-deck" baitwell due to rain despite the fact that I have a boat cover. It is a p.i.t.a. It is essentially one of the lowest points in the boat so it is gonna happen. I dont think there is a solution except storing your boat indoors. I am kinda in the market for a temporary building which cost about 3K or so and then I am gonna burn my boat cover until nothing is left. My old 78 20 ft seacraft master angler had a bait well on the gunnel and the newer seacrafts basically took this idea I guess. I tend to use these gunnel bait wells on my boat more than the below deck one even though they are smaller. Regarding the below deck bait well, there should be a "pick up" so that when you are running it is designed to push water into the well. This is a good thing if you want to keep a lot of bait alive. You should be able to close the seacock valve when you are not using this well. The gunnel bait well(s) (I have two in my 2000) dont work this way and you have to pump in the water so there is no issue there. I hope I made sense.
Steve
1978 20 ft. Master Angler (175 merc)
2000 23 ft. Seacraft (225 opti)
1984 17ft. Boston Whaler (90 merc)
Old 02-05-2008, 05:39 PM
Thanks! I will look a little harder for the cock to shut the flow off. Also, do you know of a good place to get the pumps for the two baitwells in the transom? Mine don’t work.
Schedule Sea
23' Seacraft
Twin 150 Etecs
Old 02-05-2008, 07:24 PM
rcseacraft rcseacraft is offline
I have had the pleasure of owning a 1997 Seacraft SF23 since new. There are 4 ways for water to enter the rear floor baitwell: (1) through the raw water fill pump, (2)the raw water flow through 1.5" intake with seacock (optional not installed in all boats), (3)the baitwell 1.5" overflow with seacock mounted in the transom and (4)the baitwell cover which is not sealed and leaks. The overflow will fill the well if the seacock is open when backing down hard. My boat is equipped with a single 250 Suzuki, yours may be more pronounced with the twins. Seacraft did modify my baitwell cover recess area with drains but this was not the answer. Newer 23's have seals on the cover. My boat was built towards the end of 97, so is probably very close in design to your boat.This problem and the fact that the gellcoat faded prematurely are my only real grips with the boat.
Old 02-06-2008, 01:00 AM
jwclbi jwclbi is offline
classic seacrafts?
Old 02-06-2008, 01:08 PM
Rcseacraft – Thanks for the info. Very helpful. I store my 23 with dark green hull on a trailer in the shade when not in use, so no fading yet.
Jwclbi – Sorry to taint your website with discussions of non-classics. I have found a lot of helpful info here and appreciate all input received.
Schedule Sea
23' Seacraft
Twin 150 Etecs
Old 02-06-2008, 01:21 PM
Bendlure, you're not tainting the site, I was just having some fun. this is a great place for information. Good luck with getting you're boat right.
Old 02-06-2008, 03:02 PM
Ikan Besar Ikan Besar is offline
Regardless of year ("classic" or not), this is a problem that is really annoying and one that I faced on my '76 SeaCraft. I ended up selling that boat before a perfect solution was achieved but I remember every time I washed the boat or it rained how that in-floor compartment behind the leaning post would fill so full that the hatch cover would "float" on the water under it!
I can well appreciate where the above posters are coming from, it's really a nuisance. And the primary reason why I completely did away with in-floor compartments on my current SeaCraft.
