Old 04-09-2008, 02:59 PM
whitly whitly is offline
Default 150 vs 175
greetings all. i'm a new member and a new seacraft owner. i'm looking to repower a 20' seafari. i think i have narrowed it down to an optimax, yamaha or e-tec. i want an injected two stroke, but my question is about the size. if the 150 and 175 both weigh the same thing, what are your thoughts on power, speed, fuel consumption, etc.
cheers, whitly
Old 04-09-2008, 07:01 PM
Default Re: 150 vs 175
I can't wait to hear from Fr Frank on this one..
I'm looking at the same question only with twins for a Tsunami. I would think the 175 could swing a little more prop and would more efficient at cruise and would offset it's bigger size. I bet it'd be more thirsty at WOT but would add a few mph....
Old 04-09-2008, 08:58 PM
zach zach is offline
175. No brainer (as long as financials allow). You get more power for the same weight which equates to higher top end, better cruise range and a more efficient set up. I just bought a 175 Opti Pro XS to put on the back of my 20. I'll be sure to post numbers once it is up and running.
Old 04-10-2008, 10:22 PM
what he said on the 175, I'm partial to the Etec's though
Old 04-12-2008, 07:48 AM
ok, CSC members and friends and professionals all seem to agree on the 175. so now it really boils down to optimax vs Etec. help!
Old 04-12-2008, 10:38 AM
htillman htillman is offline
My marine mechanic highly recommends ETECs. He is putting a 300 on a 23 Sceptre in a couple of weeks for a good friend.
Old 04-13-2008, 08:06 PM
The difference in quality is negligible over the run of all the motors. A specific motor may be exceptionally good, or may have problems.
In this case I would consider carefully length of warranty offered, available dealer support, relationship with a dealer, and purchase price including all accesories and installation/rigging costs !!! You have to compare the "running and in the water" difference.
Finally, do you have an emotional preference? I know some people who, all else being equal, will happily pay a little more for an Evinrude just to get the name, and ditto for Mercury.
Here is something to think about. I have personally owned 40 to 50 different motors over the past 40 years. I have owned Mercury, Mariner, Evinrude, Johnson, Chrysler, Force, Yamaha, Suzuki, Yanmar (diesel and Wankel), McCulloch and Seagull. In all those motors, I have only had one "bad" motor. Just one. It was a 1984 Johnson 140 with electrical and VRO problems.
People slam the old Chryslers, but I had two bulletproof 105 Chryslers on the back of my 25 Mako back in 1976 while I was a commercial lobsterman for a season. They started immediately every morning for 8 months, and neither one ever hiccuped during 1400+ hours of use in that time. I also had a 15hp Chrysler kicker motor push a 25 Robalo 74 miles back from the Bahamas in 1984, running full throttle for 12 1/2 hours, without a hitch when the main engine quit.
I won't pay more for a Mercury, but with all else truly being equal, I'll pick a Merc every time. Just emotional preference. But I started with a Mercury KE7 back in 1968 racing plywood hydroplane "kneeboats", and over the years, I have owned more Mercs than all other brands put together.
Ultimately, you go with what makes you feel comfortable. Both the Etec and the Optimax are very good motors.
Fr. Frank says:
Currently without a SeaCraft
Old 04-16-2008, 05:42 PM
Good to hear from a new Seafari owner! (PM me your e-mail address and I'll send you some brochures on that model and an engine comparison spreadsheet I put together.) You're going through the same decision process I did when I bought my Seafari, without an engine, in 1975! I went with OMC because the Merc's at the time seemed to have lots of corrosion problems in salt water. A friend of mine who bought a new Seafari with a 150 I-6 Merc is now on his 3rd one, the first two being replaced due to corrosion problems. This was before the V-6's came out, so the choice was between a 115 and 135 V-4, both 100 cu. in powerheads. I don't know how long you plan to keep the boat/motor, but I finally picked the 115 for durability reasons.
An old mechanic in Jupiter at Barden Boating Center (Now Jetty's resturant!) who supported the local commercial kingfish fleet, told me that a 115 would outlast about FIVE 135's! He said the commercial guys would buy a new motor every year, and they all bought 135's. He propped them for normal loads, but they'd go out and load up with 1000 lbs of kingfish, and then run back in at full throttle, which is about the only way they ever ran them. They started blowing powerheads, so he converted all of them to 115's, and they had no more problems. He said the 115's had enough margin to withstand that type of abuse, where the 135's did not. Top end speed difference was estimated to be only 3 mph. The 115's were a less highly tuned engine so they also idled better, started easier and were generally less temperamental. I ran that 115 (really only 90 hp at the prop) hard for over 30 years and about 1000 hrs with no durability problems. Made the 175 mile trip to the Abaco's 6 times with a very heavy load, cruising at 4500 rpm all day long at about 20 kts, with no problems. It was also a very light motor at only 300 lbs, so the Seafari was well balanced and rode very well in rough seas with it. When I finally decided to repower a couple of years ago, the old motor was still running fine, but I wanted newer technology with less noise, smoke, and better fuel consumption.
The only motors I considered were the E-Tec, Optimax and 140 zuke 4 stroke, because of weight. The Honda, Yamaha, and bigger Suzuki are simply too heavy for the 20' hull IMHO, especially if you want it to be self bailing! (The 20' hull was designed in the mid 60's when the biggest motors were about 300 lbs, so I believe that going heavier than that progressively worsens balance, min planning speed, and rough water ride.) The opti probably has the best cruise fuel consumption but I eliminated it because it's just as loud as the old motor. The Zuke seems to be a good motor, and lots of guys on the site seem happy with them, but it's only a 122 cu in powerhead, so I would expect it to be a high rpm motor and a little weak on mid-range torque. I ended up picking the E-Tec because at 155 cu. in. it's very strong on mid-range torque, and most of the milder (lower HP/cu in) E-Tecs seem to be under-rated by about 10% (it's REALLY a 165 hp motor per BRP's own brochure). I might have picked the 115 due to ~ 50 lbs less weight, but they were not in production at the time. As it turns out, the 150 V-6 is a very smooth, quiet, sweet-running engine that is actually a little quieter than the 4-strokes at cruise because it doesn't have to be wound up so tight. Fuel consumption is in the 4-5 mpg range at cruise; at trolling speeds, it runs 8-12 mpg, the most efficient of ANY motor, due the very lean stratified charge combustion mode the E-Tecs run below 2000 rpm. As for durability, I've had absolutely ZERO problems in 2 years and about 120 hrs and have only used 2 gal of XD100 synthetic oil in that time. Have only been back to dealer a couple of times for ECU software updates and I-Command gage problems (Stay away from the "Classic" analog-type gages; the digital ones made by Lowrance, although harder to read, are cheaper, easier to install and apparently trouble free.)
As for the 150 vs 175 vs 200 choice, the manufacture's association (NAEBM?) simply requires that the advertised hp be WITHIN 10% (+ or -) of the real number, so I suspect the real number comparison is approximately 165 vs 180-185 vs 195-200. Since I've seen 49.9 mph on the GPS on my rig with full fuel, but top down and otherwise light load, I've concluded that the "150" is plenty of power for the Seafari. Most guys probably think that "more is always better", but I'd be inclined to pick it over the 175 or 200 because it might be a little more economical and it's certainly lower stressed based the fundamental HP/cu. in. criteria. Don't know where you're located, but when offshore around here you can't often run the light 20' hull much over 20 kts without going airborne, so an extra 3-4 mph (over 50 mph) really wasn't that important to me.
I would definitely recommend trim tabs; I added them after my first Bahamas trip and they made the boat ride like it was 2-3' longer!
