Hi guys
Question should i connect the neg of the of the battery to the ttop Why my friend are scare of the lightings is that dangerous in a boat? thanks |
NO NO, Not to the negative on the battery !!!
All metal should be bonded to a grounding plate on the bottom of the boat. IE: Bow rails, rod holders, Out Rigger holders, T-Tops... You get the picture. Usually 10 gauge tin coated copper wire to every locatation mentioned above, then to the Bronze bonding plate. See ya, Ken
See ya, Ken © |
Osmany,
You might want to check this out. this guy David Pascoe covers many subjects and is a good starting point in getting yourself educated as to how systems work the way they do and some of the pitfalls of the untrained attempts of well meaning boat owner/repairmen who try to do the right thing, but just don't know what they need to to do the job right. Good luck. Here's the URL: http://marinesurvey.com/yacht/Electr...AC.htm#Grounds
Getting home is more important than getting there! Plan accordingly! |
But don't connect the engine to the bonding plate....???
