Old 06-23-2008, 08:10 PM
RalphNitt RalphNitt is offline
Default 23' SeaCraft pulpit construction
Our gameplan is to router 2 pieces of 1" StarBoard - gluing them together and adding a 1/2" PVC backer in the anchor locker. Everything thru bolts except the anchor light - and we are building it up on a 4" hollow pedestal so lightbeam can clear bit and anchor. We are using a Fortress FX-11
anchor with 12' of 3/8" SS chain and a 3000lb swivel attached to a thimble to 600' of 1/2" braided nylon line. It all ties up to a SS bit and dumps into the locker through a SS hawse.
"The sea is selective... slow at recognition of effort and aptitude, but fast at sinking the unfit" ...Felix Riesenberg
Old 06-24-2008, 07:13 AM
Default Re: 23' SeaCraft pulpit construction
Being that I am a novice here, my question is gluing together?
I always thought that starboard can't be glued. Or needs a special glue and that it still is not a good product to glue.
Old 06-24-2008, 07:38 AM
I wasn't sure either about bonding StarBoard until I asked a personal friend that builds locally and claims it's legit. I ripped off the info from the King StarBoard site for everyone to read... I am also thru-bolting which should not weaken it.
It is preferable to mechanically fasten StarBoard but when an adhesive is necessary you can use a product called #7540-AB or 3M's Scotch-Weld DP-8005. We do not represent these products, make any claims about their abilities or except liability for them. We have however used them with success and had good response from others who have used them.
#7540-AB is sold by Adhesive Methods and Technologies, Memphis TN Phone 901-367-1335 Fax 901 367-1308. Ask for Larry Doring.
How Should StarBoard® Surfaces be Prepared?
The surfaces to be bonded should be lightly abraded with a medium grit sandpaper before cleaning the surfaces with acetone, Toluene, or alcohol.
StarBoard should then be flame-treated on the entire surface to be bonded with a propane torch. Pass the flame over the surface at a distance of approximately 1" to 2" so that the blue (oxidizing) portion of the flame is touching the surface of the StarBoard at a rate of approximately 12" per 3 seconds.
There should be no scorching or visible difference in the surface appearance when properly treated. Ideally, the surface prep should be performed within one hour of the bonding process. Make sure to flame treat in a safe well ventilated area.
Old 06-24-2008, 07:48 PM
We routered the two pieces today and we will order the glue tomorrow. We will photograph the process of bonding as we do it.
Old 06-24-2008, 08:02 PM
Looks good!!! Could you have hidden an aluminum plate inside for strength??
Old 06-24-2008, 09:20 PM
We were discussing that this evening... what do you think about an aluminum plate sandwiched between the StarBoard?
