My savage currently has 1 weak coat of bottom paint. My plans are to remove it and ultimately paint the entire boat which the painting process may not occur for several months. I do wish to use the boat in between and was wondering what the best removal process would be of the current paint. Stripping it or sanding it off?
Seacraft's for life !!! |
It depends on what kind of paint is on there, and how well the surface was prepped. My standard answer would be to get someone else to do it
If you were closer to me, I could sodablast it...
We've done a 23' SeaCraft recently for a member. If you're keeping your boat in the water, make sure you use a barrier coat (epoxy) before you bottom coat. Both gel-coat and bottom paint are porous - and who wants blisters?
"The sea is selective... slow at recognition of effort and aptitude, but fast at sinking the unfit" ...Felix Riesenberg |
I too would like to know the best way to remove old bottom paint. If possible, I dont want to damage gelcoat which may or not be good though I assume it will be.
The paint is VERY old, the kind they quit selling YEARS ago. While using mild acid to remove brown stains, it would remove the paint too. I would rather not sand. Heres a couple pics of what I mean The rear area is probably the sparsest though the hull has hit and miss areas too |
MHO. The 21 I have did have 40 years of bottom paint on it. I tried chemical strippers and sanding. Trust me when I say, take it to a soda blaster, pay the dollars.
Thats what I did. The blasting will not hurt the gel coat. But you will have to prep and paint again.
Take it from the guys who've done it and if you got the cash have soda bash. If not check out this test from
practical sailor http://www.franmar.com/practical.html I've seen the soy sauce on ebay for $75 ... good luck oh, yeah, let the stripper do the work. Apply with brush usually in one direction, let sit and remove with a 3" putty knife. Save the sanding for paint prep.
I have used this stripper. It works well on everything but bottom paint. I have a quart for sale, it you want to try it on your boat. I would give it a+ on anything but the bottom.
Where are you located ? I need one soda blasted. I hope its near the Big Rock that I fish !
I'm in Morehead City
My boat is in Morehead. How can I get up with you ?
