Old 07-16-2008, 05:50 PM
abl1111 abl1111 is offline
Default Wanted: Tsunami / Sceptre foldable ladder
The d*mn SC ladder ! I need one of these if someone has one.
Or, I would like input on how to make one that is similar; light and strong - made of wood, plastic, anodized aluminum ? I have posted for this before but it ended with no real solution. Although there were a lot of people who tried !
The hard part is - ' what can be used as hinges / pivots to allow for the fold-ability factor ?' Awhile ago, someone mentioned something like a mini ball-joint type thing. Any ideas ?
Old 07-16-2008, 06:46 PM
Default Re: Wanted: Tsunami / Sceptre foldable ladder
if someone can post pictures of an original it would help....
Old 07-18-2008, 10:32 AM
EBEACH EBEACH is offline
Alan,
I had suggested the rod end. We went through this about 2 years ago. At that time, I picked up 16 stainless steel rod ends, had a cnc router available to me, and I needed dimensions. The rise and run dimensions are most important along with the mounting width. I’m not sure how to best mount the thing (hardware).
I believe the tie rod method is the best way to engineer the ladder with the ability to fold flat and have the hardware concealed for the most part. The rod ends I have are about 7/16” on the ball end with a hole for a 0.187 shaft. The end is female with about a 1/4x20 thread. View FK Bearings website.
My thoughts on how to make it:
Using quality Baltic birch plywood (3/8 ~ ), machine two pieces that will be glued / laminated together to form each tread. The treads would be routed out to accept the 0.187 shaft using a cove bit (half round cut out on each half). Also, each tread would need a cut out to conceal and house the ball of the rod end. Install two rod ends on the 0.187 wire/rod (on each end of the tread), place in the cove cut out on the tread, and laminate the two halves together. Each tread will have 4 rod ends (two on each end).
The risers would have through holes for the 1/4x20 screw to mount the treads to the riser. Furthermore, the riser would have a recessed hole (not all the way through) that is concentric to the 1/4x20 hole to house a portion of the rod end (give it support) on the inside of the riser. Screws with finish washers are inserted from the outside of the risers through the 1/4x20 hole and thread into the rod end that mount inside the recessed hole.
Keep in mind that the inside width of the riser (stringer) would determine the space between each tread, in order for the ladder to fold flat. I would also suggest that a more stout piece of wood be used on the risers, and maybe so on the treads. In order to reduce weight, I would also suggest removing some of the material (hollow out) on each half. Leave ribs and bosses in there to provide support where needed. Drill holes in each mirrored piece to place dowels for alignment when gluing the halves together.
Unfortunately, my project is on the back burner, and the ladder is not the first thing I need to tackle at this moment. I can help out with some CAD work if you come up with some dimensions (width of tread and riser, rise and run, and mounting options). There are plenty of shops in Long Island that can rout wood with a cnc router. Check your local sign shops or die board houses.
Jim
Old 07-23-2008, 06:39 PM
"E"
I sent you an email
Old 07-25-2008, 10:08 PM
E,
I read, and re-read that. OK, I read it a few more times! It's quite an endeavor. I can visualize 90% of your design. It sounds like it would work for sure. It also sounds a little bit beyond my capabilities.
Which tie rod ends do you have exactly ( I went to the web site you mentioned to try to match the dimensions you gave and couldn't. Why did you get female ends ? I would think that male ends would allow you to go through the riser and attach w/ a nut easier ?
I like the concept of the tie rods. It's clean, strong ( I'm sure much more than needed ) and so far - the best idea I've seen or can think of. Although, I have thought of just using some industrial sized SS hinges, bolted on an angle - through each, to connect the treads to the risers...
Old 07-26-2008, 11:35 PM
htillman htillman is offline
Here's some pictures of the 23 Sceptre ladder:
Old 07-27-2008, 11:44 AM
Et23, any chance you can post a pic of the ladder installed on the boat. Not sure how it mounts. Do you leave the top hatch in place or does it have to be removed?
Old 07-27-2008, 03:09 PM
ET
PM sent
Old 07-28-2008, 11:13 PM
Alan,
Sorry for the delay in getting back to you. I have been very busy latley. The rod ends I have are SAE size. It looks like they only list metric now.
I had selected the female ends because you can use any length screw for the thickness of the stringer. Also a screw with a finish washer would look better than a nut on the outside of the stringer. Once things settle down at work, I will work on some CAD drawings. Does anyone have dimensions? I can do some renderings in 3d, but that does take some time, and I don't have web space to post a picture.
Jim
Old 07-29-2008, 10:33 AM
I sent a PM...
