ok, i thought they dont work on thru hull scupper but i have read the do?? can i put the rabud ball scuppers on my hull and water not come in?? not thru transom but thru hull is what i have????
The Raybud ball "check valves" are designed for thru-transom scuppers. Do a search for Fellowship's "Vortex" check valve device for thru-hull scuppers. They work pretty well but they won't fix a fundamental problem, like an engine heavier than the boat was designed for!
I have used the Rabuds for years and years....
Bob Hewes was the first to use them on the BoneFisher over 15 years ago when I spotted them at the Miami Boat Show. They work great !!! Just keep some spares in the boat. After about 5 years the rubber gets alittle stiff and they do not seal as when they were new. Still the best out there !! ![]() ![]() See ya, Ken
See ya, Ken © |
Why would the Rabud ball scuppers not work on thru hull drains? the drains on my 20SF come out on the bottom corner of the hull side, very near where a thru transom drain would exit.
Dilligaf,
Sorry for the miss information I was thinking through the transom. I have never seen a through hull scupper on a 23 inboard. I can't wait to see your performance numbers with your diesel! |
