Old 10-21-2008, 09:11 PM
BillPutney BillPutney is offline
Default hyd. steering help
I broke the bolt that connects the hyd. steering to the motor steering arm.It sounded like it was in a bind when I tilted the engine up,there was a loud pop. Should both sides of the mounting brackets move freely or is one of them mounted firmly.See pics.I had to take the brackets off to get to the broken off bolt.Any suggestions as to how to remove the broken off bolt.I removed the hyd. assembly so that I might be able to drill it out. The bracket you see still attached will not freely rotate. [image][/image] [image][/image] [image][/image]
Old 10-21-2008, 10:30 PM
Default Re: hyd. steering help
heat, and lots off it, got all sorts of thinks to worry about with it though, be carefull.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 10-22-2008, 12:34 AM
The black cast pieces should rotate freely but not loose. I believe Sea Star has good instructions on WWW.
Old 10-22-2008, 07:26 PM
I put the torch to it and within 45 seconds the inner part started to melt,I did not realize it was not metal like the outer piece,see photo [image]http://[/image]
Old 10-22-2008, 07:44 PM
After the torching , the inner part rotates freely but the metal arm is still very hard to move.Is this arm threaded on? The corresponding arm on the other side slid right off the shaft.
Old 10-23-2008, 09:10 AM
The "stud" goes through the engine tube and is supposed to be loose (and greased). The bushing you melted, black cast alum., and stud should all be free to pivot when motor is tilted, but not so much to be sloppy. The starboard side should have a knurled (OD), threaded (ID) ring w/set screw to adjust the slop AFTER the lock nuts are tightened. Check their website for a drawing. Typically crud gets between all the stuff and you know the rest. A good soaking and understanding how it's built will help.
Old 10-23-2008, 07:57 PM
I just managed to break loose the arm , you were right it took lots and lots of extreme heat. I'm going to use some crocus cloth to polish up the shaft before i remount the arm.What should I grease the shaft with before mounting . After this lesson learned I will grease/lubricate this joint periodically from now on.
Old 10-24-2008, 01:24 PM
Use Kroil to loosen that broken off bolt. Let it soak in overnight and then apply some heat to the tiller arm, which should be steel, so a propane torch won't hurt it (but keep it away from motor cowl!). Best penetrating oil I've ever seen! Pratt & Whitney used to use it on seized bolts that saw 1200-1400F, temperatures that no anti-seize compound will survive. A friend of mine that has a side business overhauling turbochargers also uses it and swears by it. Good hardware stores carry it, but you can also order it direct or from Eastwood, the outfit that sells car restoration stuff.
Old 10-24-2008, 07:53 PM
okay guys I have just finished trying to get the shaft out of the tilt tube.I've gotten everything off both ends of the shaft soaked it and heated it .I put the lock nuts on both ends and hammered away with a 4# hammer that we use on the tractor occasionally , Nothing moves , only crushing the lok nut ends.Local Suzuki dealer says I need to replace the tilt tube , but obviously the shaft has to come out first.$64.00 for the tilt tube and none on the East coast,he located some in CA.$ 80.00/hr. for them to try and remove it and no idea as to how successfull the attempt might be.Any suggestions other than biting the bullet and saying FIX IT!!
Old 10-25-2008, 09:05 AM
depending on how mechanically inclind you are, first of all, the zirc fitting greases only the pivot point, has nothing to do with the steering arm or tube, do you need to replace the tube? Take a wire tube brush and clean out the tube, if you need to replace the tube, cut it half in the middle, us a cut off wheel, cut a section out then bang it out from the inside out, when putting it all back together use yamaha marine grease, on the aluminum elbos to to the stainless rod use Tef Gel, going to need alot of heat, just keep the transom protected, wet rag, keep the heat centralized, use a acetalyn torch, not a can, be carefull, heat the bracket, not the tube or rod.Also use a good freeing lubricant like blaster or something, orrrrr open up the check book!!!!
1974 40' Eagle
www.parkeryacht.com
