Old 03-01-2009, 02:09 PM
Default High build coatings
Does anyone know what the stuff is called on Kenms boat in the fore sale section...I'm talking about the flecked deck coating...I'm looking for a high build fiberglass coating/leveling compound. Thanks
Old 03-01-2009, 03:22 PM
Ed Ed is offline
Default Re: High build coatings
Strick-
That finish is called speckle finish or web finish. It is basically colored gelcoat that is shot out of a gun....it is used very frequently on work boats, etc. and hides imperfections on surfaces that are not 100% fair.
Next time you see a carolina skiff....take a closer look and you will see what I am referring to above.
Old 03-01-2009, 03:40 PM
Thanks Ed still having trouble finding it on the internet...does it come pre mixed like that?
Old 03-01-2009, 04:43 PM
This might help.
Webbing Solution 1 Pint- A resin based additive thats added to gelcoat at a ratio of 2 parts gelcoat to 1 part webbing to achieve a "web" effect. Used generally in the second coat after applying a solid primary coat. Decorative effects produced by the webbing mixture will vary, and relate directly to techniques or gun adjustments. A fine hairline spider web pattern results from plenty of air and scanty material flow. Coarse and splotchy patterns are created by fuller material flow and decreased air volume. Experimentation will help determine the desired effect. Item: 2040
Supplier of webbing solution
I have not used the product, this is just something I knew about.
Old 03-01-2009, 04:54 PM
Ed Ed is offline
I watched my friend do a hardtop once. He kept adjusting the gun to get it to spit out the gelcoat in the desired pattern. The additive that previous poster mentions makes sense...but I cannot recall if my friend used something similar.
Old 03-01-2009, 05:50 PM
Thanks fellas thats what I was looking for
