Old 03-02-2009, 04:07 PM
hvaldezz hvaldezz is offline
Default Repainting a 20CC
Hello again! I want to repaint my 20CC and have a question: When going over the boat recently it appears the original color was a yellowish gelcoat color underneath. It was painted white when I bought it almost 2 years ago and am wondering, is there a paint stripper I could use to get all the white paint off and take it back to it's original color? The paint looks like some type of marine paint like Petit or something like that.
If anyone has any ideas on getting it off they would be greatly appreciated.
Thanks again.
Hank
Old 03-02-2009, 04:21 PM
Boatboy6 Boatboy6 is offline
Default Re: Repainting a 20CC
Im not sure but i think you have to do ALOT of sanding
Arioch
Old 03-03-2009, 01:55 PM
I tried bottom paint stripper/remover and it DID NOT work at all.....
Old 03-03-2009, 03:17 PM
Rich Rich is offline
Are you going to repaint or are you trying to restore the original gelcoat?
If you want to take all the paint off you might be in for a lot of sanding. Removing bottom paint with a soda blaster usually is very sccessful, I'm not sure it would work to well for topside paint. Someone else might be able to chime in here..
If you are just going to repaint, you might be able to get away with using a high quality primer and and skip the process of removal.
Cape Marine Supply
Old 03-03-2009, 06:08 PM
I'd go with what Rich said, if you want to go back to gelcoat, I'd get used to the paint. In addition, even if the paint was enamel, you could prime over in and put on a polyurethane based paint, provided the enamel has been on long enough, sounds like whatever is on there is pretty tough.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 03-03-2009, 06:32 PM
I think someone did this in one of the northeast boating magazine, he used soda blasting
Arioch
Old 03-04-2009, 11:27 PM
Default Re: Repainting a 20CC - Reelclassic
Guys thanks for all the inputs. I guess going back to the original gelcoat (yellowish color) is probably not an option as the work sounds tedious and will take a long, long time, and in the end will probably not work.
Question for all, especially Reelclassic: What's a good poly paint to use to paint it white again that is easy to put on and will be sturdy? As always you guys are all the best advisors I've found online.
Hank
Old 03-05-2009, 05:40 PM
Guess it depends on how good you are with roll n tip, if you are good, either Sterling or Awlgrip, if you are going to spray it, Sterling, Awlgrip or Alexseal. Those are the top poly paints, you could go down from there to Imron,PPG,Etc. Or you could go with an acrylic paint---------
1974 40' Eagle
www.parkeryacht.com
Old 03-03-2009, 03:16 PM
I think you may need to find out what the paint is. Stuff like LP is a kissin cousin of epoxy and virtually bullet proof. If thats the case I'd take a liking to the color
According to Practical Sailor this is the best one. I have never used it but maybe next time. Surely it's better for you than the Marine Stripping Gel I use.
http://www.franmar.com/product_info....products_id=85
Either way you will do some sanding.
What did you use Reelclassic?
Good Luck
