Go Back   Classic SeaCraft Community > General Discussion > Cape Marine Supply
Old 03-07-2009, 09:09 PM
Rainmaker Rainmaker is offline
Default Maybe you can help me....
I have a lowrance 111XC that I have hooked up to my etec outboard via the Lowrance-net NMEA2000 interface. It is connected on one of 3 Ts I have in my system. One goes to the head unit, 1 to my GPS, and the third to the Etec. I have 120ohm terminations on each side. The GPS is working fine. I have updated the software in the head unit, and also the etec. I am not running i-command gauges (just a standard tach).
With all that said, I still can not see the motor on the bus set up screen.
Is there something I am missing here?
I assume the buss is correct since the GPS works. I would think that it would see the motor and add it to the list, but I have to be doing something wrong.
Old 03-07-2009, 10:14 PM
Rich Rich is offline
Default Re: Maybe you can help me....
Not sure I will be able to answer this question. What year and model is your Etec?
Cape Marine Supply
Old 03-07-2009, 10:28 PM
2006 225hp
Old 03-08-2009, 12:41 AM
Ok. I will do my best to help figure it out.
I'm going out to celebrate my girls Bday...
I'll get back to you...
Cape Marine Supply
Old 03-08-2009, 11:27 AM
Take your time... enjoy the Birthday. Those only come once a year.
Old 03-08-2009, 12:52 PM
Maybe check the output of the GPS? I know Garmin defaults to a special Garmin language, you have to tell it to output NEMA0183, which I thought was ind standard, I haven't heard of NEMA 2000, but I am by no means an electronics expert, perhaps Rich can enlighten us?
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
