Old 05-06-2009, 03:57 PM
1Step 1Step is offline
Default Jackplates?
Has anyone put one on an 18 or a 20 for that matter?
I'm toying with an idea for a livewell (the under the leaning post idea didn't appeal to me that much) and if the motor was 6-8" set back I think I can get it to work.
Will the plate help/hurt the performance of the 18?
It's not about quantity, it's about quality...and the experience.
Old 05-06-2009, 04:26 PM
Default Re: Jackplates?
A jackplate on an 18 or 20 would work fine. It has been done before. Should pick up a bit more speed.
Old 05-07-2009, 01:26 AM
follybob follybob is offline
I also have an 18 and have though about this often. If you do it, please let us know how it turns out. Seems like moving 400 lbs 8" to the rear could make the boat into a lowrider at the stern.
Old 05-07-2009, 08:48 AM
Bob, that's some of my concern although the Johnson 115 I have on it only weight 350#.
Will moving the engine back that little really affect it that much?
I am probably going to go with the 6" at the most as I think that will give the clearance I want and will hopefully minimize any squatting.
Old 05-07-2009, 09:53 AM
Forum member TheTowBoat had a 20SF w/ a jackplate holding a 475 lb Suzuki 175 off it and he did not have a problem.......Do a search on his posts from over 2 yrs ago.
Old 05-07-2009, 10:58 AM
Snook, I found his post(s) and it looked like he had a 10" with that 175 and only had minimal squatting .
Bob's makes a 5" & 8" in the model I can afford but don't know if 8" will be too much.
Any recommendations?
Old 05-07-2009, 11:17 AM
I would stay with the smaller one for less squat as you had mentioned in your prior post.
