Old 07-02-2009, 05:30 PM
BillPutney BillPutney is offline
Default oil ratio
What is the correct oil/gas ratio for a 91 70 hp. Mercury outboard. The boat belongs to a friend that just bought it from a mechanic who told him to put double the normal amount of oil for the first tank and 1.5 times the amount on the second tank during break in period.
Old 07-02-2009, 08:18 PM
bridgeman bridgeman is offline
Default Re: oil ratio
If the oil injection is hooked up you'll need to pre-mix 50:1. I'd run it that way for a 20 hrs or so, won't hurt anything other than fowl the plugs if you idle for extended periods.
Old 07-03-2009, 03:26 PM
Normal 50/1 as mentioned if oil injected judt put another 50/1 in the tank - if not then run it at 25/1 premixed
Old 07-03-2009, 08:16 PM
I told him to add 50 oz. to 10 gals for the first go round.That should be close enough don't you think ?
Old 07-03-2009, 08:17 PM
The motor ie not an oil injected model
Old 07-04-2009, 08:08 AM
If the motor is not oil injected you need to run 25:1 initially eg. 1 gallon of oil added to 25 gallons of gas for at least the first 10 hours, I'd go 20 hrs and lean it up after that.
