Old 07-14-2009, 04:16 PM
kneedeep kneedeep is offline
Default trim tab size
thinking of putting benett trim tabs on the 23'. will 9x12 be ok or do i need to go bigger?
Old 07-14-2009, 07:52 PM
joshmon71 joshmon71 is offline
Default Re: trim tab size
I think the general concensus is you want to be 12x12, with the 12" inch width of the outer strake being the limiter. some folks have added the drop fin kit to the 12x12 bennets or got them with DF installed per bennet saying works well. also the volvo ql leveling system is seeing some usage and good reports.
1977 Seacraft, Armstrong Bracket
275(chipped 250!) Verado
Merc Rev 4 17P
Old 07-14-2009, 08:00 PM
zach zach is offline
Go bigger, 12x12 at least, and go with edge mounts if you can.
The bigger the tab the less of it you have to use.
Old 07-14-2009, 11:07 PM
Bigger is better !
12 X 24 on a 20SF
See ya, Ken
Old 07-14-2009, 11:15 PM
bigeasy1 bigeasy1 is offline
I put Bennetts 12X12's with a 3" drop fin on my 23 Tsunami.
They were recommended to me by the folks at Bennett.
Actually,they told me that they would like to see 12 x 24's,but because of the steps in the hull,it isn't possible.
**(But now I see No bones with 24" tabs,so maybe the Bennett guys were mistaken)**
The 3" drop fin,adds considerable lift.My boat is an I/O,with a 350,so it's stern heavy.
It performs perfectly with these 12x12 tabs.The boat hops up on plane instantly,and if I drop the tabs,I can stick the bow down,where it needs to be in snotty water.
I would go with 12x12's with the drop fin.As mentioned,Bigger is better with tabs.You may not need them all the time,but when you do,the extra lift from bigger tabs is nice.
All this,just for a boat ride
Old 07-14-2009, 11:55 PM
i don't see any info on benetts website about the drop fins you guys are talking about. anyone have a picture of one
Old 07-15-2009, 02:20 AM
JOEKEN JOEKEN is offline
Maybe this is what they are reffering to.
http://www.anchorexpress.com/BENNETT...Tab-p/m120.htm
Old 07-16-2009, 08:25 PM
wtenglish wtenglish is offline
Have you looked at using the Volvo's? I've read some good things about them on this site.
Will
