Fuel filler hose in my 1973 23'cc must be replaced. Any tips on the best way to do this?
No one has ever had to replace a fuel fill hose even with the addition of ethanol to gas???
Been there, done that.
Use a hose nipple and clamp the old and new hoses together at the gunwale. Don't cut the new hose to exact length until it's in place. Then pull the new hose into place using the old hose as the guide/snake. Make sure you clamp securely. Simple. Not easy, but simple.
Oh yeah. It's easier if the tank is removed.
Job done. Brought the hose up from the tank with tie wraps connecting both inch and one half hoses. Secret....spray lots of SILICONE spray on the hoses, near the connection. Slipped right on through up to the fill port on the gunwale.
Next, I have to do the vent hose. |
Any recommendation out there?
20' Mako 175 'rude Sacto, CA looking for a landlocked 23'-25' Seacraft ![]() http://classicmako.com/forum/topic.asp?TOPIC_ID=13979 |
JFM, did you have a hard time getting the hose loosened from the foam from the filler cap to the tank? I put in an inspection plate to access the 1 1/2" fill hose and the vent, but can't seem to break the filler free. Any suggestions? This is kicking my butt!
MARLIN...I did not have any foam around the fuel filler tube. Just the 4 bolts holding the filler tube in. Those were difficult to get at but I was able to remove them. I just undid those 4 bolts and pulled the filler tube up from the top of the gunwale. The boat is a 1973 CC.
