Wanted to get some opinions on this older engine. Is it hard to get replacement parts for this engine? How about a lower unit for instance? What about a good cond. used LU?
This motor is carb. Will it survive on E-85 fuel? If so will it require a bunch of maint? The reason I ask... This is the current motor on our boat. Just got the boat back from my brother. Motor ran fine last time out, albeit 5 years ago!! A small crack in the Lower Unit casing has GROWN. Now it comprimizes the LU. No way it could be welded. Pictures later today.
I have a Merc manual from late 70's early 1980's that talks about their fuel hoses being rated for 10% ethanol. You might go through it and double check . . . Those excels are built on the 2.6L block . . . so I'm 99.9% sure any 2.6L lower will swap. They come in 1.86:1 or 2.0:1 ratios. SEI sells brand new lowers for yamaha 2.6L motors for $795 with a 3 year warranty.
http://www.sterndrive.cc/Merchant2/m...ory_Code=SE416 My budget prevents me from buying new outboards, but I have ZERO issue taking a well maintained older motor on a long ride. Those excels were strong for a smaller displacement motor . . . they have the horizontal front and make great power for a 390lb motor. Check the shift shaft when you have the lower unit off. |
Junk that lower unit!!
2.6L - 225 hp - 411 lbs - 1.80 gear ratio
Ok, this motor has a gear ratio of 1.80:1
************************** Warning - dumb question of the week!!!! ************************** So if the tach reads 5000 rpm is that the rpm of the prop OR rpm of the engine head / shaft??? I always thought RPM was of the prop.
http://www.nadaguides.com/default.as...&d=17002601901
Just check the shift shaft, clean the carbs, check all the hoses, run it with premix first trip out each season to make sure oil pump is working. |
http://forums.screamandfly.com/forum...ha+Excel+Lower
The 2.6 v-6 gearcases are all interchangable. The models prior to the 1986 model had a different shape than the 1986 and on. The 1986 and later were all the same housing. The 1.73 gear ratio was available only in the old stle gearcase for the v-6 Special also known as a 220. The Pro V 150 had a 2/1 ratio. The Pro V 200 and the Excell or 225 had a 1.81/1 ratio. The rest had a 1.86/1 ratio. The parts are interchangable in all of the later model gearcases. The 3.1 liter gear cases will all bolt up to the 2.6 even though a different size housing. They have some 1.75/1 gears in some models. Hope this helps. To the best of my knowledge they were all available in counter rotation. ***************************************** Hope this link helps!! ***************************************** |
