Old 09-27-2009, 05:06 PM
avian22 avian22 is offline
Default temp. for 1992 Mariner 150 Magnum II
Haven't had a problem. Just seems really Hot.
Under 3000. . . No problem! When I "Put it Down" temp. goes up to like 190-200 and stays there (doesn't over heat). Just wondering. . . Is that normal? Used it several times and hasn't created any problems.
Been told that "the higher the rpm's, the lower the temp. because there's more water pumping through". And I've also been told that "the higher the rpm's, the higher the temp. because the pistons are working more" (this makes more sense, but I'm not a mechanic. . . YET!)
Thanks
Old 09-27-2009, 07:46 PM
BigLew BigLew is offline
Default Re: temp. for 1992 Mariner 150 Magnum II
Try an extended flushing with a salt removing solution. (Out of water and running in a tank for a while.) It could be that you have enough salt/crud build-up to restrict max flow. Just an idea and a cheap "fix."
You might also add a second run using a mix of H2O and white vinegar. The mild acid will tend to dislodge/ disolve mineral deposits as a result of higher alkaline water sitting in the warter jackets between uses. I shouldn't harm any of the surfaces.
Plan accordingly!
Old 09-27-2009, 07:56 PM
stumpie2 stumpie2 is offline
sounds to me like you have a poppet valve that isnt completly opening or not opening at proper temp. also if the motor has run hot in the past the wax inside the copper or brass 'cup" on the thermostat wont force the thermostat to open at the proper temp. as the wax gets hot it expands and pushes the tstat open if it has been extremely hot before and some of the wax expands out this would cause the tstat to not completly open or open at a higher temp. just my 2 cents
http://i729.photobucket.com/albums/w...ictures007.jpg
I DONT KNOW, BUT I'LL GIV'ER HELL TRYIN!!!
Old 09-27-2009, 08:10 PM
I have a 1991 Merc 150 XR4. Your Magnum II is the gray version of the same motor. My engine temp stays constant around 160 after initial warm up regardless of load.
My XR4 experienced the same problem you describe after the powerhead was rebuilt a couple years ago. Turned out the poppet valve was reinstalled incorrectly. If you have a water pressure gauge, it should read between 10-15 PSI at cruise. If the pressure is way up at cruise, and your temp gauge swings back and forth between 180 at cruise and 120 at idle, I would say it's probably the poppet.
Dave
Blue Heron Boat Works
Old 09-27-2009, 09:09 PM
Thank you gentlemen. Gonna make immediate inquiries on both ideas.
So most Defenitely not ok to be running at 190 something degrees at 3500rpm's right?
Old 09-27-2009, 10:00 PM
Salt starts to come out of solution at about 160, which is why most marine engines are set up to run cooler than that. If you run hotter than 160F on any raw water cooled engine, you're building up salt deposits!
Old 09-30-2009, 01:45 PM
I think 140 is a good target - I would also look at the poppit valve
Old 09-30-2009, 07:44 PM
i think my 84 runs a little cooler than that while on plane. then again i dont have t-stats either. altho last time i was out i had perfect water pressure but temp went a little higher than normal. poppet is pretty new too and so is water pump.
