Old 10-11-2009, 10:38 AM
mnwnvc mnwnvc is offline
Default image test
Well hot damn, I finally figured out the photo posting. Seems to be a little different for a MAC This is MichaelA's 20. The usual new transom, floor OK. Repaint with one part poly. Wood is salvaged Brazilian cherry flooring. New 115 Opti Apollo prop. 41 mph GPS. Found this site about the time everything was done but enjoy reading every day.
Old 10-11-2009, 10:43 AM
Ed Ed is offline
Default Re: image test
Nice boat, but I am even more impressed with your lawn. Is that real grass or that new Brady Brunch synthetic grass?
Old 10-11-2009, 02:46 PM
Real grass, I just spray paint it green every couple of months.
Old 10-12-2009, 12:18 AM
dragin22s dragin22s is offline
lol was thinking the same thing
Old 10-12-2009, 09:55 AM
Brady Brunch- late breakfast or early lunch?
Old 10-13-2009, 07:32 PM
Very late lunch. Have you seen Alice`s knife skills?
Nice use of the leftover cherry. Like the montauk style windshield too.
GFS
oh, and welcome to csc.
Old 10-13-2009, 08:13 PM
Another possibility- create a profile mold of your hull and laminate 1/8 strips of mohog with West System. Trim on edge on the table saw, I know sounds scary but works. Use this at your own risk. Bolt or and screw on edge, plug. Teak with all of it's oils does not glue well.
M
Old 10-13-2009, 03:22 AM
muddywater muddywater is offline
Looks great
I like the off white color you chose for the innards. I will be curious to know how the 1-part paint holds up because it sounds alot easier than potentially poisoning yourself with Awlgrip. It looks like you are getting pretty good speed out of the Opti too!
Old 10-13-2009, 07:49 AM
I have sprayed Imiorn and looked at Agrip before painting this. I used Interlux Brightside Polyurethane and their primer Pre-Kote. Shot with a cheap pressure pot spray gun, outside. I was very happy with the results. This is the third year on the paint job without wax and there is still great gloss. There is some wear on the deck but real easy to roll on another coat. Interlux also recommends this paint also for the roll and tip technique. Make sure you keep a wet edge as you spray.
Old 10-13-2009, 12:12 PM
BigLew BigLew is offline
Michael_A,
Those appear to be some VERY nice spray rails you have on the work of nauticl art. Do you care to share details about them; material, dimensions, supplier, fastening method, self -installed or pro? You get the idea.
Thaks in advance.
Plan accordingly!
