Old 10-26-2009, 08:53 AM
aldo aldo is offline
Default mid-ship storage box
The mid-ship storage box drain on my 23 has a drain in the rear but always collects water in the front. I'm thinking of drilling a 1" hole and installing a brass flange for drainage.
Has anyone tried this?
How much clearance is there between the bottom of the box and the keel? Or is the box fiber glassed to the keel? Any other things I should be concerned about by doing this? Thanks.
Old 10-26-2009, 09:41 AM
htillman htillman is offline
Default Re: mid-ship storage box
Center console or Sceptre?
Old 10-26-2009, 11:34 AM
Center Console, inboard.
Old 10-26-2009, 12:42 PM
MasterBaiter MasterBaiter is offline
Glad you brought this up - so does mine. Not much water but some.
Why would you put a flange in it after drilling it? Does the rear have one? Mine just drains into the bilge. This doesn't seem correct to me, but there are no marks around the hole to show me otherwise.
Old 10-26-2009, 02:58 PM
Mine also drains rear into the bilge- just a hole in the fiber glass and some water always remains in the front. I thought about drilling a hole in the front and putting in a flange to prevent any water from seeping into the glass. It's easy enough to life caulk it in place with the flare on top. (not enough access to flare both sides) The big question is how much space is there between the bottom of the front of that box and the hull?
It would be nice to have that water drain off.
Old 10-26-2009, 03:07 PM
Oh now I understand the reason for the flange. I thought you wanted to run a hose to a pump or something. The only problem I see with a flange is that it would raise the edge of the hole pretty much defeating the reason for the hole. If you are going to drill and are concerned with absorption maybe paint the exposed glass.
I figure this winter I would build a wooden slat type bottom for the compartment. Enough to keep anything out of the water and ventilated so it might dry.
