I am running a 140 zuke on a 20 Master Angler and though I love the economy and reliability my top end is only 32 knots. This is plenty fast for my needs as you can seldom open up a 20 footer offshore anyway, but I do wonder if something is wrong with the set up. Prop is a 14x19 aluminum. Anti cav plate is about 2" above straight edge on keel. I get my max spped by trimming up a bit with tabs up. This with one person on board, 60 gallons fuel, two batteries in front of console and a large fiberglass t-top. Boat is a little squirrely at this speed so I don't care to go faster, it just seems like it should from talking to other people. This at 5800 rpm or so. Thanks for any feedback.
I'm no aerodynamics expert, but consider your large t-top is likely affecting your speed in both drag(acting like a parachute) and exacerbating bow-lift(more like a lifting foil) simultaneously pushing your stern down. That would account for the front end getting squirrely at speed. Likewise trimming up (bow up) would theoretically increase the drag on the top.
What prop model are you using? I would guess with the extra weight of the 4-stroke, albeit a light one, you want a wheel that lifts the stern a bit. Mounting height-wise, 2" might be a little high but with a big wheel it might not hurt too much. If you can easily remove the top itself you might try that and give it another whirl. I'm guessing you'll easily pick up 3-5 mph.
I whouldn't consider lowering the motor as it sits so low now I worry about it being underwater so much. The bracket on the engine is currently about 1" or a bit more above the transom. I will definately raise transom to 25" when-if I repower.
I hear that, harry.
Didn't realize you had the 20" shaft. I have similar concerns with a 20" on a Seafari. I would think 140hp making 5800rpm with a 14x19 should push an MA a little better than that. Can't help but think that there's a more effective prop out there for you. Anyway, try to identify your prop model - perhaps its geometry is not optimal for your MA. If it's not too much work, try removing the hardtop, and seeing if its drag is not the culprit. If its only a handful of bolts it's not much time lost on a simple experiment. Good luck. keep us posted, Iv'e been looking at Zukes lately based on some of the other guys experiences. ![]()
The top is going to have to come off soon anyway as the deck is getting pretty bad and I have to do something about it. You can feel the floor moving on port side when running in a sea. I think the console is the main thing holding the top on on that side. That is a good idea to run it without the top. I was thinking of changing to a small dog house as on my previous 20 SF and this might help make up my mind. The weather in MA is getting pretty dicey and this may have to wait till spring.
I removed the T-top today and ran the boat on a lake. Very calm. My GPS antenna is on the T-top so I had to use a hand held. Just hit 37mph, about 32 knots. I am kind of suprised that there is no real improvement in speed, although the boat did feel more stable. That T-top is a heavy sucker.
I think I remember Trayder mentioning his boat topped out around 32/34 knots with the 140 Suzuki.
I would pick up a 3 blade 14x20 stainless prop. that aluminum prop is probably flexing due to the boats weight. I get 42mph out of my boat. also if your boats decks are soft you might have alot more weight in the boat than you know about,I.E. water logged decks. I just bought a 14x20 powertech. I am going run it soon I will let you know what the results are.
36' Yellowfin 1972 20' seacraft 140 suzuki http://www.classicseacraft.com/commu...ad.php?t=18607 |
I'm glad to see those numbers from Trayder's boat. Pretty much the same. If I wreck my prop I'll get a stainless one as I saw a performance increase on my previous Seacraft with one. That was a 20SF with a 120 Evinrude looper but I don't remember the prop sizes. I hope to open up the floor this week to see what I'm up against when the snow melt. Waterlogged wood and or foam could be an issue i suppose.
Billy, I'd be very interested in the numbers on that new prop.
I bought Trayders boat; this summer on flat calm, one person and about 30 gal in the tank, My WOT was an indicated 40, GPS'd at 38 kts. Aluminum 3-blade prop (I believe 13x 17, but don't have it handy). I believe this boat is a bit lighter than most 20s. |
