I'm looking for a control box that will fit a 1998 90hp Johnson. The one I have is very rusted out inside. The mounting holes have rusted through and it is being held on the console by wood screws into the fiberglass. Will a later model control box work? I need whatever will work. Any help would be appreciated!
Oh - I guess they call it a binnacle? |
A binnacle control is mounted into the surface of the console, and the key switch is remotely mounted. A control box, also called side-mount controls, generally mounts to the outside of the console or to the gunwale and has the key switch mounted into it.
This is a binnacle control: ![]() This is a control box:
FrFrank,
Thanks! I have a binnacle mounted on top of the console that also has the ignition key incorporated with it. I'll get a pic in the morning. |
never seen one with a key, that may be hard to find
you might try Mike at American Marine down in Tarpon, they have all kinds of stuff laying around. You never know, just tell him where your from they have classic SeaCrafts - Mike or Mario, Mario is the pack rat 727 938 9796
My MA has got a 1999 Johnson 175, binnacle with ignition, kill switch, and alarm speaker all within, or as one unit. Salvage yard would be my first try. Good Luck. Part II.
I've also got one. An OMC binnacle with key switch, tilt/trim and all the cables, electrical harness and two sets of control cables from my 23' SC. It was actually connected to a 200hp. I can send a picture if you want.
