Old 05-03-2010, 03:06 PM
CValle CValle is offline
Default Prop for 23' Inboard Re-Power
What is everyone's experience with props for 23' inboard? Just repowered a 23' with a 300HP mercruiser with 1.5 to 1 gear and 1-1/4" shaft. The old prop was a 15-1/4x14 3-blade. Have been told to go to a 16x16. 4 or 3 blade?
Old 05-03-2010, 05:17 PM
GetReel GetReel is offline
Default Re: Prop for 23' Inboard Re-Power
My records indicate the original spec was 16 x 17 3 blade with 5* cup and that's what was on mine. I am running a 16 x 16 4 blade on the same 1.5 gears. Max wheel size is 16 or the prop rumble will be overwhelming. I like the 4 blade, but you'll have to buy it 17 and have it cut down to 16 x 16, they didnt make a 16 when I did mine.
Old 05-03-2010, 05:24 PM
What kind of speed and rpm performance are you getting with the 4-blade. Thanks for the response. Appreciate it.
Old 05-03-2010, 06:48 PM
aldo aldo is offline
I'm running a 16 x 15 with a cup on mine.
Power is a 350/260hp Marine Power with efi.
My most efficient cruise is at 3400 RPM and 23 knots.
wot is 30 knots.
Curious how the extra hp moves the boat.
Old 05-03-2010, 06:52 PM
Also about the 3 vs 4 blade
Old 05-10-2010, 12:55 PM
I have A 454 Marine Power 330 MPI / FWC installed 2001. Actually just rebuilt last year. The original was the Ford 351 LH 1.5 tranny and burned about 8 gal per hour per orignal owner.
My numbers are about the same as those most have, 3250RPM cruise gets me about 19.5 - 21.5 knots depending on load and wind/tide variables. I hit the top end at about 30 knots at 4600/4800 RPM WOT. I can cruise at about 3400/3500 at about 22.5 knots but thats not her sweet spot. I dont really track fuel burn much but I would ball park 12 gal per hour full load for the big block appetite. I can go about 35 off with spare fuel leftover and make it back by keeping her at 3000 and 19 knots on the way out with full load and not pushing too hard, drop in lines early, troll back in etc.
I like the 4 blade for improved hole shot and I think also improved slow speed handling, although, we all know backing this boat up can be humbling. I just had my prop reconditioned and last year I did epoxy barrier coat job and I think I have picked up 1.5 knots on that.
Good Luck.
Old 05-07-2010, 01:04 PM
riprunner riprunner is offline
CValle,
The whole time I have had my 23 inboard I have not been happy at all with the performance. I started with a 15x17 and moved to a 16x17 per the stock specs and got the same exact poor performance. I was working the top of the engine too hard and wasn't getting anywhere near max RPM. Last fall I sent the prop out to Yohan in New Bedford and he changed the pitch and must have sprinkled some pixie dust on it. I only had a chance to take the boat out for a 20 minute run afterwards because it was the end of the season It was like a different boat, quiter, faster, more responsive, and better on fuel! I can't believe how much difference it made by making adjustments to an existing prop. I'll be back in hopefully this weekend, I'll post my new results soon. I'm located in Falmouth innner harbor next to pier 37.
Old 05-08-2010, 05:46 PM
Gary Hill Gary Hill is offline
Mine has a 350 CARB, 315 HP and I have a 16 X 16 with a little playing with the cup to get the correct RPM 4600.
I usually run at 26 around 3100 RPM and 37 wide open with 3 people on it and get on the offshore trips for wreck fishing (don't usually turn it off unless I have another boat with me)I have gotten a lille better then two miles per gallon.
GARY
76 SEACRAFT CC INBOARD
Old 05-09-2010, 07:58 AM
Gary,
Is that 26 knots or mph?
Either way, it's good. The extra hp makes a difference.
Old 05-09-2010, 10:18 AM
@6 MPH, I use that because the couple of friends with SEE Vee's and SEACRAFT's ask what MPH and RPM's I'm running.
GARY
