Old 10-21-2010, 04:00 PM
redsonfly redsonfly is offline
Default damp feet in an 18
Short of raising the floor in the 18, what fixes have worked the best on a 1989 model year boat (drain through transom)?
Has anyone tied the port cockpit drain to the starboard through hull drain the way others have done on the 23's? Is there enough room to do that?
motor is a 130 hp yamaha 2 stroke v4, batteries in the console, oil tank in port reach down area of transom (below the drop in bucket).
Things I am considering are to silicone seal off the rear molded in bait well and going to the TH marine ball scuppers... Any other suggestions?
Old 10-21-2010, 09:34 PM
76Red18 76Red18 is offline
Default Re: damp feet in an 18
Use those scuppers but a little water will still eventually find it way in. Let it drain into the well and pump it out with a 500 gph auto pump. run the hose and wiring through the drain in the well to a thru hull fitting. Seal the well drain with 5200 to keep the bilge dry. Its the only way I've been able to keep my feet dry. Mines a 76 but should be similar.
J. M. Hendrix
Old 10-22-2010, 08:48 AM
This was in mine when I bought it, (still there).
I keep plugs in all the time unless running. I hit the bilge pump occasionally to make sure the bilge is empty. My Suzuki supposedly weighs 410 lbs., so, mine IS low in the stern. However, the water stays behind this bulkhead. I have my original molded splashwell and plan on putting it back on as soon as I recore it. When I do, I'm filling in the wide drains on the well and put drain plugs in so I can control the inflow. You might think of doing that. A PO attached some 3/8" plexiglass with 5200 to cover the wide drains, then drilled holes to accept drainplugs. THAT would be a quick fix, something you could undo.
Old 10-22-2010, 09:14 AM
Just found this pic.
Old 10-22-2010, 06:26 PM
Hi, Uncleboo!
I did a search back 5 years and came across your pics and ideas, but my boat has a different configuration than yours, it is the tracker model and it has a scupper out the back and a 25 inch transom.
My problem isn't water in the motor well, a problem that you and 76Red18 have seemed to address so capably, but water coming in thrugh the scuppers that have "one way" flaps on them and intruding into the cockpit.
I keep my molded livewell plugged, but when it's full it adds another 150 pounds to the stern of the boat, exacerbating the already tenuous low deck problem.
I am going to add the auto bilge pump as suggested by 76Red18 into the molded in well, and I think a pair or possibly a quad of the ball type scuppers will keep most of the water out.
Thank you so much for the ideas!
Redsonfly
Old 10-23-2010, 09:39 AM
The RayBud ping pong scuppers work well on my Slacker 20. Far better than flappers.
Mr. Moesly crossed the scupper lines which is a very clever solution as well.
Cheers,
GFS
Old 10-23-2010, 09:56 PM
Crossing the lines is brilliant, I am just wondering if there is enough room in a tracker 18 to do so. Is the idea to use PVC and fittings or just use high quality water hose?
Old 10-25-2010, 11:54 PM
CaptBoland CaptBoland is offline
I've had the same problem in my 20ft. The ball scuppers work the best.
