Is it necessary to take off your outdrive and bring it inside for the winter when winterizing your motor? What are the benifits? It is a bravo one outdrive.
Thanks |
If it is going to freeze where you are it is a goog idea to change, or at least check the oil in the drive to make sure no water has gotten into the drive that may cause it to crack when it freezes.
http://i224.photobucket.com/albums/d...t/0a21e0b9.jpg |
while the drive is off,everything can be inspected-gimbal bearing,shift cable and drive shaft bellows...trust me,pull that drive once a season ! reinstall it,after servicing it-no need to store it inside... also,if the bellows are more than 5 seasons old,i recomend you replace them...
I agree with everything that pelican stated.
Steve B 1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH! 1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop |
no need to pull the wheel if it has a rubber hub-freezing temps will never damage it...age and impact will tear it up,cold weather isn't a factor...just be sure to pull the wheel once a season-lube splines and rinstall
side note: use no grease with mettalic compounds-especially "never sieze" you can create a galvanic reaction...
