Old 12-03-2010, 02:22 AM
Default 1977 20ft Master Angler Restoration
Time to start tearing into another project.
On tap is
-New floor raised 4"
-New enclosed transom with bracket
-Recore top cap
-Add glass and fair out sides of boat on inside
-Fix all holes, cut outs, scraps, dints, dings etc...
-Blast bottom paint off
-Fix trailer fenders
-New 50gal gas tank
-New rub rail
-Repaint outside fighting lady yellow and off white inside
My father had a couple days off from work and started taking the motor and t-top off for me today. Then I brought it home and started taking all hardware and things off. Amazing how fast you can tear down a boat compared to how long it takes to put it back together. The first pic is with a Johnson but recently bought a Yamaha 150 4stroke.
Old 12-03-2010, 05:48 PM
mitchman mitchman is offline
Default Re: 1977 20ft Master Angler Restoration
Nice ride! I am assuming that the previous owner was the cut the gunnels back and exposed the inside of the unfinished fiberglass? I ask because I would like to cut mine back as well. Unfortunately I don't have floor there so that could be a problem. Id like to see more pics of how the gunnel/line is cut out in the front if you don't mind. Thanks and good luck!
Old 12-03-2010, 05:56 PM
That's how the MAs were built. The cap and liner are different from the 20 SF. MA's gunwales are wider and rise higher above the hull/deck joint.
Dave
Blue Heron Boat Works
Old 12-03-2010, 06:50 PM
Dave
Oh gotcha. I can see that clearly now that I look at the photos again. Thanks.
Old 12-03-2010, 09:10 PM
Michael Vezzosi Michael Vezzosi is offline
A lot of similarities to my 79 MA. Didn't realize that other interior gunnels may have had carpet glued to the unfinished woven roven glass. Thought a previous owner had installed it for some type of sound deadening or something. Would look a whole lot better finished right. Best of luck with your mods.. Part II.
Old 12-04-2010, 06:05 PM
I was under the impression that carpet was put on all of them, but I am not sure. Got some work done today. All I have to do now is remove the gas tank and get the bottom blasted next week before I put it up on boat stands. I will get some more pics this evening. Thanks
Old 02-06-2011, 09:22 PM
basswacker basswacker is offline
What is the purple puddy type stuff that you used?
Basswacker
Mmfishinglures.com
1976 23' Scepter
Lift weights get dates
Old 02-07-2011, 01:37 AM
West System 407. Used it with epoxy on the transom and bottom of hull. I will fair the rest of the transom with quickfair. Got the top cap off. I am just replacing the wood at the rear of the cap. The rest is in alot better shape then I thought.
Old 02-08-2011, 01:48 AM
Got the inner fiberglass cut out and cleaned up. Used paper to make some patterns that I traced onto the divinycell. Now I just need to sand alittle more. I should have the top cap back on by the weekend. I am going to keep the braces under the cap. From the factory they just put some mat connecting the brace to the cap, and it has cracked almost all of them. I will grind these out and replace with a couple layers of glass. Also drilled out all the previous repairs to the cap and will redo them.
Old 02-13-2011, 04:20 AM
Ended up using 1/2" for the top cap coring. Got the braces under the top cap glassed and the front bulkhead. Used some West system 410 to start fairing the transom.
