Old 01-05-2011, 07:55 PM
DANNY18SC DANNY18SC is offline
Default 18 with a 90?
how do you think me 18 will perform with a 1990 90 hp Johnson with a 17 pitch prop? it is a 20" motor and my transom is 25". should i look for a 25" midsection or cut the transom?
78 18'
89 200 Yamaha
http://i1215.photobucket.com/albums/...1227/boat4.jpg
Old 01-05-2011, 10:40 PM
Default Re: 18 with a 90?
You need more than just the midsection; you need the right driveshaft to go with it. Don't cut down the transom. Let me repeat that: Don't cut down the transom.
Fr. Frank says:
Currently without a SeaCraft
Old 01-06-2011, 09:48 AM
since your boat has a 90, seems my 18 CC would do fine with a 90 and one day i could look for a bigger motor. anyone know of someone with all the 25" pieces for a 1990 90 johnson?
78 18'
89 200 Yamaha
Old 01-06-2011, 09:54 AM
I agree with Fr. Frank, don't cut the transom down. I wish mine was a 25". I don't have any problems with the 140 4s on my 20" transom, HOWEVER, you won't see me going out in snotty conditions. I spend most of my time in the Albemarle Sound and only go in the ocean on nice days.
Old 01-06-2011, 05:15 PM
http://www.baymfg.com/
This is what you need to make that 20" motor a 25"
Old 01-07-2011, 01:04 AM
You really need a 25" 115 at best, I bet you can do with a sale/swap in those years pretty easy. Sell yours and buy a 115, should be pretty even and easier
Old 01-07-2011, 01:31 AM
I agree - if you add the $ you'd spend on the 25" extension kit to what you'd get for current motor, you might be able find a newer 25" 115. The 90 (used to be an 85) and the 115 are both V-4's, so same block and about the same weight. However motor condition/compression is more important than age. Would be best to get a loop charged model (60 degree V) instead of the older cross-flow 90 degree V, but I don't know when they started making the loopers.
