Does anyone have an Armstrong dive ladder how do you like it is there anything you don't?
I'm need a ladder for the boat and was looking for used ones and wanted some advise on them Has anyone tried any if the other similar ones like the gerlick(sp) Thanks Matt
we need a lifeguard at the gene pool |
I have a 3 step armstrong ladder on my Parker, fits into the armstrong bracket.
Works great!! Made a little modification to the retaining ring but other than that, works fine.
I have an Armstrong ladder. The only thing I dont like about it is it is easily to leave on the transom. It will create alot of drag and bend the bracket. I have started putting a clothesline clip on the engine key to remind me to remove it.
Other than my forgetfulness, it is a great product. |
Matt
I had one before my transom enclose. They work great, easy to install and they float. The big complaint I experienced was storage... ![]()
I put a windline on my contender.
It had an Armstrong but the plastic steps broke. This was a great replacement and cost me less than replacing with an armstrong. Windline Ladder
Glen 1996 23ft Contender 08 Yamaha 250 HPDI 1965 13ft Cacci craft skiff with 20 Hp tohatsu 4 stroke 1992 20ft Shamrock Predator (Hard Top) 351 FWC PCM Repower SOLD First boat: 1988 17Ft Shamrock Open 3.0 Mercruiser RWC 140hp Traded |
does anyone know how much they stick out i have twins and would have to clear the trim tabs
thanks ![]()
You are probably better off with something like this.
Platform Ladder
That's a good set up for most diving, although if doing tank diving, you might want a 3 step ladder, with platform mounted close to the waterline.
