Anyone know how many gallons is needed for Intercote 2000e barrier coat @ 4 coats or 10 mils on a 23?
23' x 8' = 184 sq ft. approximately. (increased beam mesurement[the draft] compensated by tapering at the bow) 184 sq ft/coat
Look at the can and it should give you the coverage square footage in the can or per gallon. Figure it out from there.
Well why don't you f'n retards figure it out for me? If I wanted to do it myself I wouldn't have asked lmao.
![]() OK, A 55 gallon drum will take care of inside and out... ![]() Good to have you back in the saddle Finny!! ![]() See ya, Ken
See ya, Ken © |
Finny,
Thanks for the comment. A 23' Seacraft has approixmately 185 sq ft. of hull surface. Call customer support at Interlux and ask them to tell you what is the "out of the can coverage" of a gallon of their product and how thick (in mils.) does the product typically setup at. Take the coverage area/gallon and your calculator, then divide the coverage area/gallon by 185 and the answer will tell you how many gallons you will need to cover the hull. If it sets up at less than 10 mils, then you will need additional product. Ex. If you want coverage at 10 mils and it goes on at 5 mils then you will need 2 coats. (10 divided by 5 = 2) Get the picture? Good luck. Call with any questions- 978-363-5161.
the idea of alternating coats-to be assured of complete coverage... it's not the amount of coats-but the thickness of the coats,that's important-tape the areas around the blocks back approx 2",this will assure you,to have the epoxy to coat epoxy on,rather then antifouling paint...use the tape as a guide for thickness-10mil is basically a matchbook cover thickness...
Thanks Pelican, thats what I needed to know. Biglew was that so hard ffs?
Todd, I think I'm with Frank on that. Though it might be a little conservative ![]()
