How can i tell if my gas tank is original? also how thick is the transom on a 23 sceptre?
Every aluminum or SST underfloor fuel tank i've every seen has a mfg label on it. check yours out carefully, i'll bet there is one on it somewhere. It will have the date of mfg.
Would look something like this: ![]()
1977 SeaCraft 23' Sceptre W/ Alum Tower & Yamaha 225 www.LouveredProductsUnlimited.com |
if it is not on top where is the next best place to look?
![]() Quote:
![]() See ya, Ken
See ya, Ken © |
The transom wood is 1 1/2". Probably used 2 pieces of 3/4" plywood glassed together. I replaced mine with 1 1/2" Coosa board. Worked great.
If you dont see a tag on the tank, pull it.
If you dont see any corosion, pull it. If you have the boat half torn up, pull it. Its better knowing now, than the first time your 2+ miles off shore after just filling up and your bilge pump starts pumping fuel out of the bilge.
Patrick from WAY out on cape cod. 1973 23foot Center console, Birdsall Ttop, Hermco Bracket... in progress |
