Old 04-12-2011, 02:34 PM
SBD SBD is offline
Default Foam
What density of foam is used for foam installation of a fuel tank.
I am aware of all of the pros/cons of foam, just trying to figure out what type is used for this job.
Thanks!
Old 04-12-2011, 04:00 PM
dbiscayne dbiscayne is offline
Default Re: Foam
i've poured both 2 & 4 lb/cf foam and the foam I pulled out of my boat around the tank sure felt like 2 lb/cf.
Old 04-12-2011, 04:53 PM
wtenglish wtenglish is offline
Default Re: Foam
I believe 4lb is what was recommended to me by the supplier.
Will
Old 04-12-2011, 09:39 PM
GodsReel GodsReel is offline
Default Re: Foam
does your tank have flanges on it? why foam? if you do foam, put a thin layer of pvc board between the foam and tank so no moisture can transfer.
just my 2 cents.
Old 04-12-2011, 10:38 PM
pelican pelican is offline
Default Re: Foam
if,you properly chemically etch primed the aluminum,and coated it in interprotect,the proper thickness-10mils,then,aluminum is completley isolated from any and all moisture contact - no need for a barrier between the tank and the foam...
Old 04-13-2011, 10:14 AM
Default Re: Foam
Why add foam in the first place?
