Old 05-28-2011, 11:54 AM
Default Moesly 21...First Test Run...Movies !
They say a picture is worth a 1000 words...click on each of the pictures and see what you think
The Very First Run
Drive by at 30
35
Hole Shot
Banking Turn
Listen to my buddy's comment at the end
I will post burn rates and miles per hour later in the Performance Link of the forum.
Everyone have a happy and safe Memorial day
Old 05-28-2011, 12:03 PM
Default Re: Moesly 21...First Test Run...Movies !
Just TOO cool!!! Have a great weekend!!
Old 05-28-2011, 12:14 PM
Gee Terry, That looks mighty fun. Congratulations on the splashing! The Stroker sounds smoooth! Look forward to the numbers report. What prop are you running there and where are your tabs positioned on the holeshot? Very cool!
Have a great weekend.
Old 05-28-2011, 03:36 PM
Nice job Terry looks like she turns on a dime. Love the bow rise on that old boat. Are you going to re do the windshield? ....cant remember if you have one.
Strick
Old 05-28-2011, 06:37 PM
cdavisdb cdavisdb is offline
Looks great, Terry, and thanks for the vids, so much more information in a video. Can't wait to see performance numbers.
Something I don't understand, maybe somebody can explain. Both Stricks vids of the 25 and Terrys of the 21 show the wake pealing off at a very sharp angle to the boat. If straight out is 90 degrees, this is more like 20 degrees. Its very different from other boats wake (I haven't looked at other Seacrafts). Most boats, the wake peals off at 45 degrees or more. Even extreme deep V hulls don"t peal off so sharp as these. I noticed this with Stricks vids and have been watching other hulls since. The wake on these Seacrafts looks different from other hulls. Its very noticeable once you look for it.
Why do these hulls do this? Seems like it should be more efficient, but is there another reason?
Old 05-28-2011, 07:06 PM
Terry, she looks great! Runs REALLY flat, so you must have her balanced real well, or you had the drive trimmed in a lot! I think you'll be really impressed with the ride when you get it into some rough seas! I love seeing that chine out of the water with the slight bank! Quiet running too - did you put any sound absorbing stuff in the engine box? Looking forward to hearing the performance numbers!
Connor, regarding the narrow wake and it's sharp angle relative to the transom . . . I wonder if it's because the boat is hydro-dynamically very narrow when you're really honkin' . . . most of that outer panel is completely out of the water!
Old 05-28-2011, 08:28 PM
Terry,
It looks like you have nailed the CG.
That hull is really steep `n deep up front. The steps are in line with a straight edge drawn forward. Magic. Release the surface tension.
I think Carl and Jeanne might want to go for a spin. What prop were you running?
I have a 15.380 x 17 Mirage+ , but you have to come East to try it. Maybe a little South as well.
Cheers,
GFS
Denny,
I have a source for Pappy Van Winkle 20 yr.
Old 05-28-2011, 10:45 PM
SWEET!!!! I'm Drooling
Old 05-28-2011, 11:04 PM
Might as well head to the depot for a gallon each
of tan, forest green, & black to camo the rig...
Now that she is in the water and lookin' marvelous..
You will not take her out to finish her properly!!
Terry, Awesome job!!!!
See ya, Ken
Old 05-29-2011, 08:13 AM
Thanks guys it is a blast to drive. A real torque monster.
To answer some questions.
Running a Mirage + 21 3 blade, thanks to blue heron (Dave W)
Gilly the stroker is smooth and really quiet. On the hole shot motor down and cavitation plate parallel to the hull (trim down, then hit the button up for a split second). No tabs.
Strick, can't push to hard in the turn or she will break the prop loose. So far I have found out is the throttle back and then gently apply power when coming out. Windshield will be coming just don't know when or what. Yes I have the old frame, but most likely will not use it.
Denny the balance seems to be there and the boat loves to run with no trim tabs and with the motor trimmed down. No sound absorption material. I had it out the other day on a flood tide with chop and 2-3 foot rollers coming in the pass. Lowered the trim tabs and drove through it at 25 with not one pound and no water over the side. It is a dry running hull.
Ken, in the hot rod world we called cars like this a Rat Rod...So I guess I have a Rat Boat (it will get painted)
