Old 06-05-2011, 08:38 PM
beradtke beradtke is offline
Default rebuilding lower units
anybody ever rebuilt there own lower unit(mercury)on there own. i have a had no luck for the last couple of weeks looking for a used engine. so i have decided i will keep mine and try to rebuild my lower unit my self. i figured if the unit is broke i cant make it any worse.if i have no luck rebuilding it my self then i will buy a used lower unit and go from there.
73 seacraft 80 merc my boat
Old 06-05-2011, 09:56 PM
Default Re: rebuilding lower units
Do you have the knowledge and tools?
You can save a ton of money if you can drive the bearings off the gears.
Cheers,
GFS
Old 06-05-2011, 10:36 PM
Knowledge is the easy part, The special tools are what
will frustrate the heck outa you!!
IE: Torch set, retaining ring tool, pullers, press, shift
shaft seal tool... and the beat goes on.. [img]/forum/images/graemlins/tongue.gif[/img]
$1000.00 minimum in proper tools to do a proper job!!
You would be better off looking for a used lower in the
$350 range. Or see what a professional shop would charge. Just my 2¢ worth
See ya, Ken
Old 06-05-2011, 10:51 PM
See ya, Ken
Good advice,
GFS
See ya soon.
Old 06-06-2011, 05:15 PM
I found a used lower unit but it is a 25 in. The guy says it can be cut down to a 20 in shaft. I had never heard of this before. Seems like a waste of a good lower unit. He wants 350 plus 100 to get it cut down. He also has used switch boxes for 50 each. I know what I have and what is wrong and I would rather not buy someone elses junk. I have never took apart a lower unit but I am willing to try.
Old 06-07-2011, 01:36 AM
Go to Scream - Fly tons of 20" stuff
also SEI makes after market new under a grand - nothing but excellent reprts
DO NOT ATEMPT THIS AT HOME - the parts are the killer, forget the tools
