I bought a 1976 SeaCraft in 2005.. 1999 Yamaha V-Max 200 hp. She moves pretty good!
I have already added a T-Top ('07), then I noticed the floors were "weak" in certain areas. Had the deck reinforced ('08). Changed out the aqua cushons for white- added cushons for the step up bow area. Then a new trailer.. I'm on to the next project and I'm looking for recommendations: 1. I want to enclose the transom 2. put a dive/ swim platform on the back 3. paint the deck 4. paint the hull 5. new center console- old one is cracking/ broken where its screwed into the deck.. 6. leaning post/ cooler seat (center console is low - capt's chairs currently). I was told the transom enclosure- they go straight up from where the current storage compartments are located now- that would make a very wide transom (about 2 feet). Normal? Any new ideas for the transom- live bait well...? fold down seat (like I've seen on contenders?).. Any suggestions on ORDER of operations- don't think I can do all at once, so it will be done in pieces. Suggestions would be apprecaited! Thanks BK [image]76SeaCraft2.jpg[/image] [image]Picture 019.jpg[/image] Can you not pull pictures from your own computer? I don't have a web site to pull my personal pictures from- thats what it seems like its asking me to do..? New to this site.. ![]() |
You can pretty much build your boat any way you like to suit your particular needs..only issue may be weight in the transom
FAQ: "How do I add an image to my message?
In order to add an image to your message or your signature, you must have the image already available on a web server. This can be an image on your own personal web page, for example. To place an image within a message, simply use the following Markup Tag: ![]() For example, if you have an image called cateye.gif and its available from your own website at http://www.mywebsite.com/pics, then you would use the following image markup: ![]() You can do the same for your signature. Click the My Home option found on any page. Then, under the Main Configuration heading, click on "Personal Information, email, password...". Look for the Signature box, and enter your desired information, including any images/markup as above. Note: To keep the forums loading quickly for everyone, it is recommended that you do not exceed 35k for your image size. " So I try and type [image] (and then cut and paste from snapfish- the address bar- and this is what I get [image]http://www2.snapfish.com/snapfish/slideshow/AlbumID=6559063009/PictureID=337942458009/a=24490700_24490700/[image] |
[image]http://www2.snapfish.com/snapfish/slideshow/AlbumID=6559419009/PictureID=337955879009/a=24490700_24490700/[image]
Might be the privacy settings in Snapfish?
Nice job bushwacker!! Looks great!! I'm in the process of talking to a guy who rebuilt an old '76 seacraft like the one I have now; however, that one was done like yours- hatches remain the same height. I've asked him to figure out if we could raise the hatches to the transom level and leave space for a live bait well down the line. He is looking at it today- so I'll keep you posted.
I am leaning towards the lines on top of the bracket since it wont be coming straight thru the transom to the inside of the boat- that will all be an enclosed area in the back. Then we'll run it thru the flooring to the center console. Weight?? I've heard people say 1. you need to add weight to the front of the boat (someone said 700 lbs) 2. older seacrafts sit heavier in the water- so you might not need to add much weight to the bow. I have an "idea" but not sure if it will work. I want to put my fresh water washdown in the front hatch (been looking for a rubber bladder that can form to the space) and a reserve gas tank in the 2nd hatch in the bow step up area.. Interested to know people's thoughts on that... |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 2 bow hatches- front- fresh water washdown tank / center- reserve gas tank ![]() ![]() AND THEN THERES THE CENTER CONSOLE ![]() ![]() ![]() |
