I need to spray a boat with Awlgrip, and lost my buddies factory to do it in. Is it safe to spray outside in a neighborhood - I'm worried about overspray; cars neighbors houses, etc.
The 454 primer won't be a problem. It dries so fast, the overspray is a powder you can sweep up. The top coat is another matter. I sprayed mine inside, so I can't say with certainty what distance is safe for the top coat. I would think at least 25', but some of the other guys with more experience may have a more accurate idea.
Dave
![]() See ya, Ken
See ya, Ken © |
Thx guys - Strick, I knew that was the right answer - just didn't want to face it ! The search is on !
Dave
I'm not sure if anyone mentioned it, but here on LI with the way the humidity settles out of the air every night, you will definitely want it covered. I basically built a tent over mine, but I was only doing the deck.
I hear'ya. Last time I sprayed I waited for the weather report to be perfect. Then I sprayed the 545 outside and then built a large oxygen tent out of huge sheets of plastic within an industrial building and sprayed away. Came out great.
I asked an auto-body guy I know if I could use his room fopr a few bucks on a Sunday, but he said that his room is not set-up for something like Awlgrip... |
Your gonna want to spray it inside or under a covered carport of sorts because bugs and debris will get on the wet paint and then your not going to be happy.
