Old 08-13-2011, 09:12 PM
Default 20 sf bait tank ?
My 1982 20' sf has a bait tank I. The rear floor. There was the remains if a airiator In there the kind that sprays water to make bubbles.
And on the transome above the hull drain there is a fitting with a plug in it.seen here
on the starboard side next to the bildge pump exit is a capped off through hull
I'm wondering how theese were set up was thus capped hole a drain hole?
Ever tank I've had you turned it on the tank filled and ocerlowed out a drain hole I cat see how this could work or take in water while running
82 seacraft 20SF
Bayview Canvas
Old 08-14-2011, 01:54 PM
Default Re: 20 sf bait tank ?
BatWHat did it just recifculate the water and make bubbles ? Not fresh water continuasly ?
82 seacraft 20SF
Bayview Canvas
Old 08-14-2011, 08:35 PM
I've got mine set up to pump water out of the bait well. Water comes in through the transom drain. Pump is controlled by a float switch mounted inside a home made aluminum housing to keep the bait from getting stuck under the float.
Dave
Blue Heron Boat Works
Old 08-15-2011, 12:37 AM
Hanks for the pic.
Can you explain furthur You pump water out doese it pump n or just floe in from transome hole. Doese it flow in and out ?
I've had tanks that circulated in and out continusly I dint see how this could without a new throughthull
82 seacraft 20SF
Bayview Canvas
Old 08-15-2011, 03:21 AM
The in floor wells work better to have the pump pumping water out of the well. That eliminates the worry of the drain - they always come in easy getting it out is harder LOL
Having a flow control on the thru hull will allow for you to control the water height to keep it from overflowing easier
Old 08-15-2011, 06:20 PM
so Egg not having a clamshell as blue heron just the transome hole the the capped off hole next to my bildge exit how would you plumb it please?
82 seacraft 20SF
Bayview Canvas
Old 08-15-2011, 05:56 AM
The vertical tube is plugged into the hole that goes out the transom. When anchored or drifting, water comes in through the tube and fills the well. The float switch cycles the pump on and off to maintain the water level. When I want to drain the well, I pull out the tube when the boat is on plane or on the trailer.
The hole to the port side of the tube is connected to a clamshell through hull pickup. There's a pvc ball valve in the line that I use to control how much water flows into the well while the boat is on plane. As water comes into the well on plane, it overflows through the vertical tube and out the transom. If water is flowing in faster than it can flow out through the vertical tube, the float switch will activate the pump.
Dave
Old 12-28-2012, 12:57 AM
sidelock sidelock is offline
Dave
Dave, I'm not quite sure I understand what you are saying here or how your set up works but if the vertical tube ( which I assume you disconnect from the elbow when you want to drain the bait well ) somehow gets loose/disconnected while the boat is @ rest & the float switch/pump for the bait well fails, would'nt that potentially sink the boat ?
Also, when the boat is @ rest & you are filling the bait well through the drain/vertical tube , does the water eventually stop flowing in when it reaches a certain level somehow or do you have a shut off connected to the vertical tube like you have on the clam shell tube?
Old 08-15-2011, 05:23 PM
O blue heron I understand thebwater enter from a clamshell but if your anchored do you meen you have no flow and the water enter from the transome drain hole ?
Perhaps that why on mine someone had a airator pump
82 seacraft 20SF
Bayview Canvas
Old 08-15-2011, 08:29 PM
...but if your anchored do you meen you have no flow and the water enter from the transome drain hole ?
At rest, the waterline as just above the deck. The pump keeps the water level about 3" below the deck. Even with only 3" of hydrostatic head, the water flows in through the transom pretty well. And you don't really need water flow when you're on plane. The water sloshes around enough to aerate it.
Dave
