Old 09-13-2011, 09:50 AM
gchop gchop is offline
Default spray rail question on a 23 cc
I own a 1976 23 CC that has mahogany spray rails. The guy that I bought it from a few years ago bought it from someone in FLA. I think the boat has a leak in the rear section and I want to remove them. the question is will I see a big difference in the boats handling and ride without them. they are 4 inches wide and run from the bow to about 12 inches away from the stern. Any thoughts ?
Old 09-13-2011, 11:10 AM
shine shine is offline
Moderator
Default Re: spray rail question on a 23 cc
I cannot help becasue I have not been on a 23CC with them. I would also be very curious to hear some feedback from anyone who has been on a 23CC with spray rails.
I am at the point in my rebuild where I could pretty easily make them and fair them into the hull before painting.
Old 09-13-2011, 01:49 PM
If you have the vertical scuppers that go through the bottom, check those first. The brass tubes, particularly the flared areas, tend to corrode and leak over time. A search for "leaking scuppers" will bring up a number of threads on the subject.
Old 09-13-2011, 10:14 PM
george90 george90 is offline
i have them on my boat and seen them on a couple on here but have yet to hear how they ride. but i hear there amazing and kick ass. do you have a pic of your boat
My goal in life is to restore as many classic seacrafts as i can.
Old 09-14-2011, 01:52 PM
I replaced the vertical scuppers this year but it was not the problem.
Old 09-15-2011, 01:27 PM
ok im calling on all the SEACRAFT afficinados Here !! somebody must have an opinion or some experience on spray rails on a 23 cc. Does the boat need em ? Tell me what You think.
Old 09-15-2011, 03:17 PM
pianewman pianewman is offline
Old experience here, but from 1974-1990, on my dad's 23' Tsunami (became Sceptre), I/O, modest V-8, I don't recall ever getting much spray over the bow.
In addition, I've got them on my new-to-me 20'CC, rear-heavy, and I HATE the way they dig in if you don't pay attention while cutting across a modest wake. If the boat is leaning into a wave, the sprayrails seem to just pull down the side going into the wave.
Also, are they really 4"? I can't wrap my brain around what that looks like, and how they aren't getting ripped off the side of the boat.
...just my 2-cents...
1971 20' Seafari, 3.0 Merc. I/O
Peterson 1819 Aluminum single axle trailer
Old 09-16-2011, 10:24 AM
I have owned a 23 and 2-20's. I put spray rails on one of my 20MA thinking they were going to help. They helped with the spray put did not let me take full advantage of the trim tabs and in a sea with some chop they would not let the bow dig down as far and kinda made the boat ride alittle funny. Basically it did not ride as well.
So I decided I would rather have a better ride and get wet, then not get wet and not have as good of a ride. Curtains are a must on boats!!!
These Seacrafts are very seaworthy. Had mine out 60 miles this past weekend and caught 6 wahoos, 21 dolphins, 3 blackfins, 30 triggers, 20 beeliners. And only used 40 gallons of gas
Thinking of restoring another 23 soon and I will not put rails on mine.
If anyone is interested in some spray rails I will give them a good deal. They are plastic ones about 10ft long/each.
Old 09-15-2011, 05:05 PM
I've never seen a 4" spray rail, AND I've never seen a spray rail run more than 1/2 the length of the boat., and only one where it was longer than about 1/3 the length of the boat. (And that was on a 26' Albemarle trawler hull)
Fr. Frank says:
Currently without a SeaCraft
Old 09-15-2011, 05:12 PM
Wildman Wildman is offline
I have the same rails on my boat. I decided to keep them because fixing the 40-60screw holes and then having some oddly colored stripes down the sides of the boat wasn't an option. I was not going to paint the boat this year, that would have changed my decision I think. I am really interested to see how they run.
I would dig out the old sealant best you can, run some tape on the hull and the wood, and seal them back up with 3M 4000uv.
Those are longer than mine! I thought mine were a little excessive because they go below the old water line.
