Old 09-28-2011, 08:14 PM
GodsReel GodsReel is offline
Default scupper change from floor to transom
I have a 76 23 cc with large floatation bracket and 225 yami 4. boat drains fine and does well until you have a coulple of big guys in back. Can i get some feedback from the guys who have gone through the transom without raising floor. ie how well it works, how hard it was etc. It looks like it will be hard to get in there but it looks doable without cutting floor. I have already recored some problem spots in floor . thanks
Old 09-29-2011, 01:35 PM
Jacquestrappe Jacquestrappe is offline
Default Bump
Interested to hear people's experience with this as well. I have a similar project in mind for my 23.
Old 10-11-2011, 09:55 PM
c'mon can't believe nobody has any feedback on this , how bout it folks help a brother out.
Old 10-11-2011, 10:04 PM
Wildman Wildman is offline
Lets see some pics of the boat, and the existing water line. Each boat is a little difrent, its hard to tell without seeing it.
Whats a 'large' floatation bracket?
Whats your motor weigh?
Your stringer boxes are going to prevent you from going in from the bilge to attach hoses. Whats your plan for those?
Old 10-12-2011, 06:19 AM
Pics would help.
Chances are you want see that big of a difference. Maybe add some ping pongs to the transom if you were togo that route would help alittle.
Your floor really needs to be raised if it is still original.
Old 10-12-2011, 08:29 AM
Default Floor Scuppers
23' s don't need floor raising. My Floor scuppers ran thru the transon even before my barcket install without issues. I raised them about 1" with this current setup.
1.) Fill / Glass in old Floor Drain
2.) Glass in fiberglass tubing
3.) Gemlux Flapper type S/S drain thru the transom with 5200
4.) Tie in drain tube & Scupper with ridgid bilge hose & S/S clamps
Old 10-12-2011, 12:59 PM
joshmon71 joshmon71 is offline
i prob have the heaviest motor of anyone on a 23-a 250 verado (chipped to a 275 now). About 650 lbs. The scuppers on my rig were done by prior owner exactly as Chuck says to the letter. It is only wet if 2 guys are in the back corner, and one of the guys is over 250 pounds. Case in point, me at 175ish with an equal sized fellow this weekend,full gas,50lbs ice,gear, we had dry feet. AT rest. Both in the corner, and we tested that on purpose actually . We were talking about it in fact.
If the floor was raised a little it would be perfect, but unless i need to do the floor its not gonna happen for a few more years at least. Even then I may keep the floor at its current height, since I may not totally remove the floor to redo.
At rest the boat is self bailing right now, and its an Armstrong bracket for a 25" motor. I think the hermcos prob have a little more float but thats conjecture on my part. If i had a dream bracket it would be the hermco, with more floatation going outward than exist today. You dont need a dive ladder to get back on the brackets, and only need room for tabs.
I have the rubber flaps, they do let some water in if my fishing bud is north of 250 and we are both in corner. I prefer the flaps as i think in a pinch they would evacuate more water that than the ping pong ball types, but thats preference. IMO less to go wrong with the flaps, i dont want to think about my scuppers and ping pong balls if a wave comes over, just want them to work. HOwever if raising the floor say another inch or 2, Id go with real big scuppers like the rectangle style with flaps. Again overkill, but i do know someone who took a rogue wave offshore in their classic 23 with scuppers out the back, and bigger is better for scuppers.
1977 Seacraft, Armstrong Bracket
275(chipped 250!) Verado
Merc Rev 4 17P
Old 03-15-2022, 12:42 AM
SeacraftErik SeacraftErik is offline
Capt Chuck, where do you get the 1" fiberglass tubing?
Old 03-15-2022, 08:16 AM
If I remember, it was Widfire Marine here in Stuart. It might have been an old extendo stick.
Old 10-12-2011, 02:36 PM
Yeah they all will mostly selfbail at rest sittin in a slick creek.
Every older Seacraft I have been on, twins/singles, motor on transom/motor on bracket, floor raised/not raised, etc.... have always had wet floors at some point.
My 83' 23ft I redid, I raised the floor 4.5 inches, moved the gas tank forward, had a bracket, 2 stroke yammy 225hp would still have water in the floor on occasions. Most of my fishing and rigging is done at the back of the boat so there was always 2-3 people in the back and 50gals live well and fishing in at least 2-3 swell with a wind chop. Usually there was water in the boat. (Harkers Island Nikes, Wanchese Slippers what ever you want to call them are a must (White Boots)).. Defianltly does not scare me away from the boats. Shoot about any boat I have been on under 25' has a draining problem when you are in seas with the crew at the back. Only the 30ft's and up I have been on self bail really good. (Contender,Yellowfin,HydraSprot).
IMO I would never own a older 23' that has not had the floor raised. From my past experiences the Seacrafts I have been on without the floor being raised had wet floors all day.
Shoot even my 77' MA I raised the floor 5". It selfbails good but there have been times where I said damn another inch or two be nice. Refering to the floor that is :-0
