Hey Gang,
`96 rude 150/175 fast track system. Boy this is going to be fun. I`ve heard the horror stories of getting to the left rear screw to remove it. At least it happened in the driveway......off to surf. Cheers, GFS |
I rebuilt the one in my Yamaha. Soak it in liquid wrench for the day prior. Mine was just stuck brushes in the motor. A $0 fix. It too broke in the driveway. When I thought I needed a motor, Sierra was one of the cheaper replacement options.
Thanks fish, but I am far from stuck brushes. Normally this requires the use of great heat.
Are any of the great minds here thinking that I could use a hot and cold cycle to help break the corrosion. I have been hitting it with the new Zep product. A master mechanic thought it better than PB and Aero Kroil. Not sure about that, but I will do my research. What about freon cooling to help break the corrosion? Just fishin` here. Cheers, GFS The OEM paint seems far better than the knock offs. Thoughts? |
do you know part number may have one most lickley an arco
omc pn 0434495.
I found a NIB in Hollywood for 100 clams so I think I will go that route Thanks, and welcome to CSC. GFS |
