Old 11-12-2011, 12:20 PM
6buoys 6buoys is offline
Default differnce in plywood
whats the diffrence in the ply you by at home depot and marine ply and if covering with fiberglss does it make a diffrence.
Old 11-12-2011, 02:36 PM
In simple terms, about 100 bucks and 25+ years of service life.
Composition-wise the difference will be in the quality of the wood (species and heartwood vs sapwood), the number of layers, the voids in the wood and the glues used.
My experiences have taught me when you buy plywood at Home Depot, you get what you pay for. A professionally oriented lumber yard will have much better exterior plys than what you'll find at H-D. They may cost $50 instead of $30 for ABX or ACX but they will typically be much better. If you can't budget for marine ply look for a pro lumber yard and get the better exterior ply. I have used some real CDX that was better (read durable when exposed to the elements) than HD's typical ACX. Some of Home Depot's stuff barely qualifies as sheathing...
Covering the lesser plywood in fiberglass will not cure its structural shortcomings in marine applications, although for some things it may suffice.
Old 11-12-2011, 03:31 PM
bigeasy1 bigeasy1 is offline
Ditto what McGillicuddy said.
Marine fir plywood is similar to a good quality A/C Fir plywood,but in most cases has more Plys, and there are no voids in any of them.Regular plywoods used in the construction industry will have voids in the plys that can allow water intrusion.
You will find that the Marine plwood will also be a more rigid and stronger plywood than the regular plywood.
Personally I'd spend the extra few bucks for the marine product.The last time I bought Marine plywood was about 3 years ago,and at that time I paid $78.00 for a 4x8 sheet of 3/4".
If you have any specialty plywood houses in your area they will sometimes sell it to you directly.If not any good independent lumber yard can order it for you.
Here's a picture of two pieces of 3/4" marine fir glued together.The dark line(the black dashes) in the center is so that you can see the epoxy glue joint where I glued them together for my transom.
You can also see there are no voids,and you can see that there are more plys than regular plywood.
All this,just for a boat ride
Old 11-12-2011, 03:35 PM
"Some of Home Depot's stuff barely qualifies as sheathing..."
Gilly......you are so right!!!
Old 11-13-2011, 08:23 AM
thanks guys i know what i gotta do to make it right .
Old 11-13-2011, 10:30 AM
pelican pelican is offline
if you're smart,you're gonna move away from the whole plywood core thing...
wood cores,these require the use of epoxy - to insure the core doens't become wet,from the pourous polyester resins...
fact: wood rots...
composites - you should look into them...
Old 11-13-2011, 12:10 PM
76Red18 76Red18 is offline
Make sure you don't use fir ply form (Used for concrete forms). The ply form at most home centers is labeled B - B Structural 1. Its good quality plywood but is treated with release oil.
J. M. Hendrix
Old 11-13-2011, 01:08 PM
How is Polyester resin any more or less pourous than Epoxy resin? Neither is "pourous" as I see it. These SeaCrafts are built primarily out of Polyester resins and are Very water tight. Please explain. Comments?
Old 11-13-2011, 01:20 PM
In a related thought.....
I'm planning on redoing the transom on "Katrina" in the spring and i am seriously debating the use of plywood vs. composites. So i'm very curious to see where this thread goes and interested in knowledge opinions. So far, I'm leaning to plywood due to:
1) Availablity
2) Cost (about 1/2 the cost of Coosa)
3) Reasonable lifespan (20+ years if done correctly)
4) Workability (with standard woodworking tools)
5) Holds screws better, thus basically reduces the need to thru-bolt.
I do plan to use Epoxy resin, but hear that Vinylester resin is a close second and Polyester have been successfully used too.
Old 11-13-2011, 02:53 PM
Plywood is fine for a transom. There are several areas where plywood is superior to the foam cores (compressive strength, ability to hold a screw, and ability to absorb resin and bond to laminate/skin). Penske/coosa is great for transoms, but plywood is proven to last for 30+ years with poly resin (even with poor installations).
Here's some home cheapo Arauco plywood acx I used in my bracket. Did my 23 transom with the same wood . . . come see me in 30 years $30 sheet.
