Has anyone built there own bracket if so how did it come out? do you have pics? if there is a thread can you send me in it thanks
My goal in life is to restore as many classic seacrafts as i can. |
I've done a few of them . . . after Strick helped me through my first one. FYI - It's about $600 in materials and 40 hours of time (80 hours if it's your first one).
http://www.classicseacraft.com/commu...hlight=Bracket This is stricks nice yellow one http://www.classicseacraft.com/commu...racket&page=25 http://www.classicseacraft.com/commu...hlight=Bracket http://www.classicseacraft.com/commu...hlight=Bracket ![]() ![]() ![]() Last edited by Bigshrimpin; 11-25-2011 at 02:58 PM. |
YO Big shrimp!!
Fun looking at them old posts. Esp the one from 0'4. Sorry I missed your call yesterday...was fighting a striper and the wind at the same time. Lots of fish here now and I've found that it's almost as fun fishing as it is working on boats during the Fall striped bass run!! strick |
![]() Quote:
strick |
My dad is a cabinet maker with his own shop. So i feel when I am ready to tackle a bracket build I would be able to accomplish it with his help no problem. But after reading through some of the thread links I feel that the whole placement and mounting angles some of guys are talking about will completley lose me lol.
78' / 20SF / Merc XRi Black Max 150 |
yuo guys got my attention i also want to build instead of buy any more help would be great
I made the mold and I had to cut the part down to fit a 20 sea craft size. It was No problem tho. Take a look.
![]() ![]() ![]() ![]() This is the full 23 bracket on the 20 transom ![]() This is the bracket with the full width deck but cut down to fit a 20. ![]() Last edited by bly; 12-05-2011 at 08:19 AM. |
can anyone give me dimensions on a bracket for a 20. first time building. would like to get some idea. love the stuff i see .and hope mine comes out that good .
![]() Quote:
Height you should figure about 25 inches at the transom and and about 20 at the far aft end not counting the the Flat reinforced area that the top engine mount bolts go through for lack of a better word. If you do as I have always done and learned. You want to have a flat straight something projecting from the bottom of the hull. running parallel with the bottom and going aft to where the lower unit cav plate will be. This is where the possible improvement in performance comes from. Clean water near the surface lets prop push boat more efficient. You can sometimes raise an engine or prop height 2 to 3 inches higher near the surface with out grabbing air instead of water. Do as I did. Back ward engineer other brackets and hull bottoms and then come up with your best shot! Width is mostly for floatation at rest or off plane. This is your choice. I will tell you it is a thin line between a bracket and a stepped hull extension if you go to wide. Then you are throwing in a new equation. Last edited by bly; 12-11-2011 at 09:33 PM. |
![]() Quote:
1. Engine shaft length 2. motor clearance when tilted up. Figure these two things out and the rest comes into place. It is better if you do this in your head and draw it out on paper. 30 inch set back is a bit too much for a 20' foot boat in my mind. The 30 inch set back is for big V 8 motors that go on a 23 foot boat. Another thing....make your flotation chamber as big as possible. Good luck! strick |
