Old 01-09-2012, 06:44 PM
Default Sceptre transom rebuild
Started my transom job today. As i was cutting it out i realized that the guy that i had do it 4 years ago used pressure treated wood. What a "No No" that was. I was worried that the oil in the pressure treated did something to the laminate so i pulled both inner and outer out. Not my plan. He did not go all the way up either as you can see in the photos and all the top was completely rotten. I have three months to get this done cause i want to go back fishing.Try to get photos not used to the new method files are too large. What is the trick
Old 01-09-2012, 08:51 PM
Holy moly!!!! I'm impressed. I went as far as the inner skin when I replaced my transom. However I sorta wish I went as far as you did, THEN it would have forced me to call Hermco to go with one of his brackets on a solid transom.
GOOD LUCK!
Old 01-09-2012, 09:45 PM
Yeah i wanted to go with solid transom with bracket but i would have had to change alot of my rigging. I wasn't even sure what i was going to run into, so it is all being replaced and going back to the same way it was.
Old 01-09-2012, 10:01 PM
Not all marine ply is compatable with Poly or Vinylester. Oil in the glue or treat is not a treat at all.
Ask here to avoid the road to nowhere. My compass is spinning. Is that a problem?
Cheers,
GFS
Old 01-10-2012, 12:11 AM
pelican pelican is offline
pressure treated plywood can not be fiberglassed...
Old 01-10-2012, 07:44 AM
hermco hermco is offline
I remember seeing Mark Hoptner at Ocean Master using it in his transoms,
http://www.glen-l.com/wood-plywood/b...g-plywood.html
Old 01-10-2012, 04:21 PM
Hermco do you agree that the resin will be ok bonding to the wood that has the pt oil in it?
Old 01-12-2012, 10:24 AM
deerhunter deerhunter is offline
that looks like a big prodject. where are you in ma. i'd like to stop by and see this. been thinking of doing my 20 fter.
Old 01-19-2012, 08:42 AM
Did you remove the inner and outer skins of the transom? It is hard for me to tell from the pictures.
Old 01-19-2012, 10:04 AM
Yes I did but that wasn't the plan.
