Old 01-11-2012, 06:39 PM
Default Epoxy or Poly resin?
I am doing my transom and i am at the point where i am joining the 2 pieces of 3/4 marine ply together. I am trying to get feedback on what to use polyester resin with mat or just a 2 part epoxy resin?
Old 01-11-2012, 07:16 PM
pelican pelican is offline
epoxy resin will provide the best bond...it's best to "wet" the surfaces with the epoxy - prior to coating with a laminating mix - this assures a full bond,versus a "dry bond"...
when working with wood - epoxy is allways the best choice...
Old 01-11-2012, 07:46 PM
hermco hermco is offline
The way we did the wood core back in the day was with poly and mat, screw together with drywall screws until cured then revove the screws before installing.
Old 01-11-2012, 07:57 PM
Ok guys very good, thank you for the helpful info.
Old 01-11-2012, 09:19 PM
Always good info Don. The flex rates need to be thought about.
Cheers,
GFS
Old 01-11-2012, 09:28 PM
big fan of using drywall screws for clamping parts together for laminating - old school - but it works...
Old 01-11-2012, 09:34 PM
Drywall screws are your friend!
Old 01-11-2012, 09:53 PM
note what's in the penske board...
penetration - it's good and bad - bad when things aren't protected...good when they are...
Old 01-11-2012, 10:00 PM
Mike,
You've got the opinions of two professionals, I'll add the opinion of an amateur that's done a little research and played with both resins.
Poly is "good enough", epoxy is better. Why? For an amateur, epoxy is easier to mix, easier to work with, and has little to no odor. A guy using poly resin in an attached garage may run the whole family out of the house with styrene fumes.
Epoxy also has better secondary bond strength, is water proof while poly is only water resistant, and has the best physical characteristics of any of the laminating resins. But it's the most expensive, too.
Either will work, epoxy will work better, last longer, and cost more. So, ya pays yer money and takes yer choice.
Blue Heron Boat Works
Old 01-11-2012, 10:30 PM
bly bly is offline
Default Lets make it even harder to choose. I prefer Vinylester resin
It is a lot cheaper then epoxy. but It is more then polyester. It is water proof. Some claim more water proof then epoxy. It has better secondary bonding then polyester resin. It is thinner and wets out most glass better and easier then epoxy.
