Started to dis-mantel my Seacraft. .. I want to say thanks to Strick for giving me the courage and insight to tackle suck a Labor of love. This boat definitely need to refurbished. ..After removing the Harware and console. there was definite rot in the transom and decks..
So I basically decided to do away with the liner and replace the floor and beef up the Hull. I never thought that these hulls were that thin.. Atleast mine is... And the spray foma is crazy. But I am glad it just falls off the glass in sheets.. |
As strick may have mentioned, you don't want to leave that cap off too long or the gunwales will fall and deform some, then getting the cap back on will be extra work. Some of the guys have made retainers out of 2x4s by cross-cutting slots about 7-1/2' apart and placing the slots over the gunwale edges in 2 or 3 spots to keep the beam where it should be. That helps to keep the sagging at bay. Not sure what you mean about doing away with the liner - is your intent to core the hull? Others probably have a better idea on this but me thinks the liner adds considerably structural integrity to the boat. Good luck, looks like a nice clean project.
there's no such thing as normal anymore... Last edited by McGillicuddy; 04-14-2012 at 11:55 PM. |
Takes guts to do that. Wimps need not apply
What do you guys think about replacing that Keel ... Will the boat deform? should I replace in sections?? How can I replace with out damaging the shape of the hull? Whoops I said 76 when it is a 73 20Sf |
![]() ![]() ![]() Dang, that is a lot of foam. Haven't seen too many keels replaced either... I've talked to a guy about drying out wood with heat and air via vacuum or pressure through numerous small holes and then infusing the dried wood fiber with epoxy... kind of more in depth git rot concept...he uses this technique for spot transom and deck repair but seems like it could be effective in a keel as well. Anyway, don't let me slow you down. Looking forward to watching your project develop.
ON with clean up and grinding of Hull. Not bad for a weekend.. Now that everything is out I can plan and design How and what to do
Carl Moesly "proof tested" his construction techniques by racing SeaCraft's in the brutal Offshore Power Boat series in the '60's, where they totally dominated the outboard division! It's all documented in Carla's new web site: http://www.moeslyseacraft.com/seacraft-stockboats.html and in this thread that Big Shrimpin posted last month of the 1967 Bahamas 500: http://www.classicseacraft.com/commu...ad.php?t=23715 That race was so rough that 75% of the boats entered dropped out, but all 3 SeaCrafts finished the entire race! Denny
How does one download the PDF's, so an "Old Goat" can blow them up? Charles |
