Old 05-14-2012, 11:56 AM
jaybap jaybap is offline
Default boat name on transom
Im putting my boat name on the transom of my 20CC. Not sure if I should put boat name on one side and hailing port on the other. Or both on one side. Any of you guys have pics of yours? I need some inspiration.
Old 05-14-2012, 04:59 PM
Do you have a motherwell ut out that is why one side or the other?
82 seacraft 20SF
Bayview Canvas
Old 05-14-2012, 05:01 PM
I used do do alot of lettering snd most on a transome with outboards it was on the left and the POC was smaller under the name
82 seacraft 20SF
Bayview Canvas
Old 05-14-2012, 05:18 PM
CaptMick CaptMick is offline
I have both on starboard side. Swim ladder is on the port side.
Old 05-15-2012, 07:30 AM
GodsReel GodsReel is offline
23 but an example of on the side
Old 05-15-2012, 08:49 AM
Yeah im going starboard side with both. Thanks for the input.
Old 05-15-2012, 08:53 AM
Normally hailing ports are put on larger boats...however I do like the name on the sides for most CC.
Old 05-15-2012, 11:36 AM
csurf csurf is offline
Hailing ports are only required if the boat is documented. And according to the requirements it must be on the stern, and the name also needs to be on the both sides of the bow. My 2 cents is don't bother with it, just put the the name on her. If you decide to move the boat you'll have to change it, or if you sell it the next owner will need to do the same.
1980 23' SeaCraft
1992 16' Steiger Craft - Custom Flats Boat
The sea finds out everything you did wrong.
Old 05-15-2012, 12:36 PM
parker2120 parker2120 is offline
when i had my boat i had to put the name on both sides because i was documented for coastwise fishery,name and port on the back
Old 05-15-2012, 09:32 PM
for the record mine is on both sides
